equipment to tune with
NecroWolf
lost marbles member
i was wondering if anyone could tell me exactly what equipment (hardware/software) i need to do my own tuning with. i know i need a laptop but after that it kinda confuses me. i'm not worried about burning a chip. an emulation set-up would probably work fine, i think.
Re: equipment to tune with
My suggestion is
www.nwstp.com has the definition files for tunerpro you need and we try to keep them updated as bugs/errors are found.
I suggest new people play with the closed throttle VE table. Put the chip in open loop and play with adjusting those #'s to get the idle AFR where you want it. Save your old chip so you can always go back. You can't do much damage aside from fowl plugs in the closed throttle table so don't fear anything. Get it to idle well in park, figure out how VE adjustments affect AFR's, etc. Then put it in D, sitting there with brake and get that part of table fixed. Go back to Park (it will change) find the happy medium. Remeber you can't do much damage in closed throttle so try things. Get a good feel for what is going on.
Once you feel good there, drive at say 35mph steady see what cells are being accessed and what AFR you have. Make adjustment. Then do 45, 25, 55, etc. Get the main VE table so that AFR is where you want cruising steady state. Get that worked out and you will be amazed at how much the other stuff will fall into place. (stumbles, bogs, spool, etc.)
Everybody wants to tune boost first which is WRONG. The way the stock chip calculates fuel under boost forces you to have the drivability stuff first. Concentrate on drivability first.
When I do a custom tune for someone I spend 95% of my time doing drivability. Fuel under boost takes about 3 runs. Drivability can take a couple hours or more.
bezerk
just wondering if everybody is tuning on the knocksensor, or some people even took it out, and started to tune on EGT gasses.
i want to tune my Ty, but my KS is going bezerk on the loud rocker, so i can't get myself to turn up the boost...yet
NecroWolf
lost marbles member
so i can pull the chip out of my ecm and put the ostrich in its place and then run the cable to my laptop to start tuning?
SBNova
Yes.
Make sure youve got a laptop with a serial port (DB-9,rs232), because most ALDL cables require it. Otherwise you will be buying a USB converter, or a more expensive ALDL cable from Moates.net. Check if you have the port, then post back here.
NecroWolf
lost marbles member
i'm shopping for everything, just wanted to make sure, and i'm gonna get a laptop w/ a serial port.
LandryPoole
The FAST unit has the VE tables, but then it also shows the correction percentage that the computer is making to adjust for how far off the VE is as compared to desired air/fuel ratio input on the air/fuel ratio page. Does this tunepro have this as well? J/C I want the best tuning ability with the best ease of use. Help a brother out. I do like the Fast Unit, but it is pricey
cameronsclone
I'm with ya on tuning this thing. I just ordered an aldl cable and looking into what software to get. This thread sure helps :tup:
VermontTy
Support Our Troops
JS Manufacturing said:
wideband o2 (optional but HIGHLY recomended. You will be amazed how far off the stock o2 can send you compared to a wideband. LC1 is cheapest i think from innovate but several suppliers out there.
Jeff, does cheaper necessarily mean worse in this case? There's quite a variety of wideband sensors, software, gauges, etc. out there. Am I wrong to assume that a sensor is a sensor, and the real difference in packages is the software and how you display what the sensor is reading? School me please.....
SBNova
Landrypool- Tunerpro can show you a stock bin if you load it, or it can read your chip with an Autoprom, or you can read it with an eprom burner/programmer and load it into tunerpro. Then, when the engine is running, you get feedback from the ECM in the form of BLM's and INT's, that let you know how far off you are. You then adjust your tables accordingly. Numbers lower than 128 are rich, numbers higher than 128 are lean. Datamaster will show you the BLM's and INT's, but it isnt an editor so it has no way to display what your chip currently has on it to compare, and adjust to. So in essence, yes it helps you figure out how far off your VE tables are.
With stock ECM's you will not have tables quite so simplisticly labeled. I have heard the stock GM ecm's are more powerful than current aftermarket. They are also more complex, with quite a bit of control. The software was designed for driveability, mileage (somewhat), and emissions compliance. Altering the current software for performance isnt always the most straightforward, but can give great results with a little thought involved. With this new software that is coming soon from some members here it sounds like our stock ECM may very well be a few steps ahead of an aftermarket ECM.
The big bonus to me for using the stock ECM, is that in the event of a failure I can get one anywhere. Good luck scoring a FAST ecm on a road trip, and having it in less than a day.
That isn't as far fetched as you think. That is all I can say right now. :lol:
Cheaper doesn't mean worse. I have a LC-1 I use for my portable ecm setup/wb setup. The only thing I have found it it requires calibration frequently. Otherwise it seems good.
ashman
I believe your right. Seems like there's only two sensors most manufactures are using. What you're paying for is the display (or lack thereof) and controller.
I have the LC-1 and it works perfectly in our truck. It even has a narrow band output to control your ecm in closed loop. It doesn't have a display, but interfaces with Tunerpro for a logged display. You can add a external display if needed. It's very simple to install and the controller is small, sealed and fits anywhere (i have mine in the engine compartment).
BTW, If you plan on tuning with the new code JS and company are creating, download and get familiar with TunerproRT!!! , you'll be ahead of the curve when it's released.
This also is why most 'Dyno tunes' are a waste of money. The tuners spend all their time on 5% of WOT. It ends up putting up a good number, but it only works great at WOT.
Jeff, just out of curiousity what approach do you do take with part thottle timing? I have played with it a little but I think mostly I am just leaning out/Richening the VE in that part of the table. For NA motor they say to be careful about over timing the motors & drowning it out with fuel. I am also used to MAF cars where the fueling is mostly set by the MAF calibration (so the fuel is mostly a constant). You give the engine what it wants for timing. Start off conservative, add timing until it knocks then pull out a few degree out.
Dyno tuning is a waste of money IMO. On jeremy's syclone I tuned it the night before with wideband had it running perfect. Took it to dyno and bam AFR's were so rich the sensor was maxed. Basically the dyno CANT load your truck like it does on the street. At least roller dyno. Do you think the rollers weight exactly the same as your truck requires to drive.. NOPE.
The other reason WOT tuning needs to happen last is how GM setup the code. Under boost it takes the last vacuum VE and multiplies it by a #. (boost multiplier table F77) So now if you change vacuum condition you just changed ALL of your boost fueling also. The code59 team is working on changing this, but it does work good if you use it correctly even as GM designed. Just be away boost tuning should be LAST.
Timing tuning is very subjective IMO. Each truck can act much different. For example the day we ran 12.15 on jeremy syclone I had 27 deg of timing in at WOT on pump and meth. This is CRAZY amount of timing. It was knocking but after about 23 deg it didn't go faster either.
ashman
Any secret tips for tuning the max number of cells and keeping the truck out of PE?
How about removing the hose between intercooler and throttle body to elimate the possiblilty of getting into boost during initial tuning?
eh8475
So, let me see if I understand the correctly. The G1 adaptor replaces the chip. Then the Ostrich plugs into the G1. With Tunerpro you can change different parameters. Now if I got that correct do you keep the Ostrich in there at all times or at some point do you burn a chip and replace it.
Right foot keeps you out of boost. I know is tough but gotta have some control.
Seriously when tuning the F29 table, you want to be at steady state conditions. Start at 25mph, no change in throttle, speed, etc. Tune that cell, then move to 35mph (should be higher rpm similar map), tune, 45, shift to manual 2nd, 35mph tune, etc. Hitting as many points in VE table as possible. Very important you want STEADY state conditions. If PE (power enrichment), or AE (accelleration enrichment, DE (Decel Enleanment) are active then the data is not good for tuning VE table alone.
The memcal is a 2 part device. It includes 2 seperate portions 1 is the chip itself which contains the bin information, the 2nd is the filter/spark circuit that is specific to our 4.3 engine (why a 4cyl prom won't work, etc.)
The G1 bypasses the chip side only letting the ostrich, be in place of the chip/bin. The spark/filter section must still be there so the G1 lets those pins pass through, that is why you need a stock chip plugged into the g1. Same goes for ultimate, etc.
