dBaseD
Hey guys, I am new to Syclones, and just encountered an issue that I need a little input on.
The check engine light came on while I was driving the truck, and the Datamaster said the code was 42 for the EST being in bypass mode.
I found the EST wire and it was connected, so I pulled it apart, started the truck, checked the timing (it was at 0) shut the truck off, cleared the ECM memory, put some dielectric grease in the connector and reconnected it, started the truck back up, and it was fine (timing light showed it idling around 25 degrees or so). The next morning, I started the truck up and the CE light was on again, throwing the same code. (timing was back at 0)
I know for sure the EST wire is connected, and I dont see anywhere in the main wiring harness that the wire is broken or brittle. Any other suggestions for diagnosis before I change the distributor out?
Thanks
Jason
EDIT: The truck has an Ostrich chip running code59 on it as well. Thinking it might be a failure with the stock chips ignition controls, I tried using a different chip (another stock chip as well as a kenny bell one) attached to the ostrich adapter, with the same results. So I am pretty sure the problem is not with the ECM.
Thanks
Jason
