Estimate my 1/4 time
E.Murray
I finally got everything back together and looking good in datamaster. My flat straight spot isn't quite a quarter mile, though. In datamaster, you can get lots of acceleration measurements. Here are my times:
60 ft. - 2.119 @ 34.5
0-60 mph - 5.28
1/8 th mile - 8.886 @ 79.1
Roughly, where am I in quarter mile time? I want to see if I'm getting there on the tune. I've gone as far as I can with the data and want to know if I'm in the acceleration ballpark for stock engine and turbo on 93 octane.
sytyguy
Moderated User
Re: Estimate my 1/4 time
1/8th et * 1.56 = 1/4 et
1/8th mph * 1.24 = 1/4 et
So.....13.86 @ 98 roughly.
That terrible 60' messes with math though.
E.Murray
I figured there was some rule of thumb. Thanks! I don't get the 60' either. The mph looked ok, but time was weird. The 60' reading would be subject to the most error (being short and distance which is calculated instead of speed that's measured).
AUSyTyIN
Unbusted $#it box
A 2.1 60'? I pulled that in my stock Cavalier...
Not to sound like a dick, but do you know how to launch a SyTy?
E.Murray
As I said just above you, I don't trust the 60 ft. time. Remember this is in datamaster, not at a track, so it's measuring engine parameters. It's assuming things like tire diameter and then trying to calculate distance. So I'd ignore the 60' (since the rest of the measurements all jive with each other). Probably should have left the 60' time off...
Also, I don't do hard boost launches. It's not worth abusing the hardware for a backroad shakedown run. It's the engineer in me that cringes at the thought of the unnecessary hardship for the mechanical bits...
If your not launching it hard, then a 2.1sec 60' is probably what it is.
AUSyTyIN
Unbusted $#it box
The engineer in me tells me without a hard launch, that your 2.1 60' is probably pretty accurate.
