Exhaust and emissions
Neelsonwheels
I am in the process of changing the exhaust on my new to me Typhoon.
Some may know it as Mighty Ty. The truck is awesome and runs great.
Thanks to Dave and all his hard work. I am going to quiet the thing down a little by
removing the Dynomax 4" turn down that dropped out before the rear axle,and adding a Borla xr1 race muffler and exiting it out in the stock location all in 3".That said I have to
pass emissions up here and need to run a cat for the test then I will remove it.I bought a Dynomax straght through style.By adding the cat will this cause a over rich condition that will cause me problems? I really don't want to mess with the tune due to how well the truck runs.Please go easy on me I am kind of new to all this.The truck has a Bigstuff3
engine management system so maybe the existing tune can be saved and a more emission friendly tune can be downloaded then swapped after all is said and done?
I don't know
Re: Exhaust and emissions
If the truck is running in closed loop at part throttle, it should have a good chance of pass emmissions with the cat installed.
Neelsonwheels
I believe it is closed loop.
If I had payed better attention when Dave explained it to me I might be better off!:tup:
STORM TROOPER
every year when i go thru emiss i just turn my idle way up 2000-2500rpm only idle tst down here in az but that seems to do the job:tup:
MIGHTYMOUSE
Turbo F body guy
it should be closed loop at warm idle, hook a laptop up to it and i'll tell you where to look to confirm.
