I have an aem truboost. ...no cat and turned it off and now just use my forge wastegate running my 20g turbo. ..work great...
So I should be fine if I remove my cat????
Have the wastegate hole enlarged/ported first,,, then you can remove your cat.
I haven't really dilly dally with it yet but when I removed my cat it over boosted....I replaced the solenoid in the system and it helped but I haven't really done too much with it....so I turned off the aem truboost. ..The answer is yes with me that it over boosts but I will eventually turn it back on and play with the wastgate duty cycle to see if I can stop it from over boosting. ...I'll keep you posted...All trucks act differently also I have noticed...to be honest it's a crap shoot if you will or not...but I think you will...:headbangeSo I should be fine if I remove my cat????
