exhaust temp gauge questions
Gnocide
turbo game burt reynolds
for those who know and run them
1) where would you mount the sender unit- (down pipe near the 02- exhaust manifold etc?)
2 ) what reading are you looking for?(1700 under load- 1400 cruising etc)
i have one that has a clamp style sender( sender inside a hose clamp)
and i don't know how to tune or read with it
thanks in advance
Michael
Re: exhaust temp gauge questions
I have been planning to install one, probably in the crossover (to get pre-turbo temps). I'm surprised you aren't seeing more variation with engine load.
Regards,
Michael Pliska
Syclone #1721
I LOVE 4UM SUPERSTARS
Optimally, your EGT sensor should be place in front of your hottest cylinders exhaust port about 2-3 inches from the port in the middle of the flow....this is the way I ran them on the dyno I used to tune on. The problem is if you are still running stock exhaust manifolds, its hard to do with that style. You could drill and tap the manifold for a 1/8 NPT pipe thread and then use a 1/8 pipe adapter with a compression fiting on top that will seal and lock the probe in place. If you dont want to do that, I would say put it right near your O2 in the downpipe. The other way is the most accurate though.... :2cents:
Michael
BTW, if anyone is interested, I can probably set up a discount on thermocouples & pyrometers. I'm the Engineering Manager for ISSPRO, which is a gauge manufacturer. The R658SHT-8F-PL is a high-temp inconel thermocouple, 1/8" NPT (it already comes with the compression adapter Joey G mentioned).
Regards,
Michael Pliska, michael at isspro dot com
Gnocide
for the different areas mentioned- what should the readings be?
good info keep it coming..
MIME WAS ORIGINALLY DRILLED IN THE STOCK D/P
now i have an atr 3 inch and im thinking of putting it else where
Windedv6
Ty n 10s
I tapped mine into the exhaust housing of the turbo. This is probably the hottest part of the system as it is at a restricted area. My temps are around 850 at idle, 1,200 at normal cruising speeds and 1,600 - 1,700 at max boost. In my application the 1,700 mark is to high as that where I detonate. I have a couple of cracked pistons to show for it. I use the gauge to back out of a run if it approches 1,650. The times I stayed in it above that I paid for it. My data log spike the knock count pegged also at the 1,700 range so for my build that is where the cylinder heat (with my tune) starts to self light or detonates
Here is the thing I understand about EGT gauges. Years ago My GN friends use egt's to tune before the aftermarket computers and loggers hit the scene. You could adjust fuel, boost and timing combinations while keeping the egt's a point just below detonation and meltdown. You didn't really know what a AFR was excatly so you added fuel or backed off timing to make it run cooler, etc.
Please understand this when using these gauges for more than just another cool gauge to look at.
Do not go by someone else's temps...
Heads and head work make a difference
Fuel types make a difference
Plug types make a difference
Your tune makes a difference
The EGT location makes a difference
Outside air temps make difference.
Since you do not need the EGT for tuning today, the EGT gauge is normally used for a determinded threshold for warning purposes on your own setup. Get to know what your own setup can handle to determind where your limits temp limits are.1,600* on my motor my kill someone else motor at 1,600*.
John
Gnocide
Re: exhaust temp range for placement questions
update-
i have a westach 0-2000 egt gauge and a clamp style sensor,
it is supposed to be put where the o2 sensor is on the down pipe(drilled in )
does anyone know what readings here are good and whats the danger zone?( cruising at 70- wot at the strip etc?)
any advice would be appreciated
