exhaust valve stem seal
Falco
Howdy,
I'm just putting together my L35 heads. I've an SBC valve stem seal kit (#12511890). It consists of oil stem o-ring seals for both exhaust and intake valves (sit into second groove on valves), seals for intake valves and two kind of seals for exhaust valves. No problem with the o-rings and with intake valves. However the Service manual says "no seals for exhaust valves". I removed my stock heads and found seals on the exhaust valves. So what should I do? Should I put seals on the exhaust side too? Also there are a normal size and a .030 over size seal (said to be used on vehicles with >8400 GVW). Which one should I use? Note that I found almost impossible to put on the o-rings if the exhaust valve seals are installed. No problem on intake side or one exhaust side without the seals.
Did a search but found no exact answer... Pls help if you can.
TIA,
myclone
Have the heads your using had the valve guides replaced or do you have a used pair of heads your just putting new seals in?
If they are used then I always put the O rings on both intake and exhaust along with the seals that fit over the end of the valve guides. If the heads have been rebuilt with new guides then I dont use the O rings aad only install the seals that fit over the end of the guide.
Ive never used the over sized seals you mentioned myself so I really cant comment on wheather they are needed instead of the stock size. If I had to guess Id say use them if they will work ok upon careful inspection one you have one assembled.
FWIW. Im working on a write up about how to replace these seals but Im still searching for the proper pics of the diff kinds of valve stem seals as visual aids help tremendously in explaining what goes where.
Falco
Thanks. That's a pair of used heads. Got the assembled and found no exhaust seals on them (o-rings were there). Dissasembled the stock heads and the exhust seals are there. Anyway, I gonna try to use the normal sized exhaust seals...
If you can't find good pictures, I might try to take a few.
Thanks again,
GAShan
Try these. PAW PIO 08938PA Oil seals. Set of 16 is $24.00. Nice trick set for L-35 and stock heads. Not umbrella type, they don't start leaking down like stock seals.
Falco
Thanks. I guess these are positive type valve seals. Just did a little search I'm not finished yet, but these positive type seals seems to be the ultimate solution. Also I got the intuition that you shouldn't use umbrella type seal and o-ring seal together. Use one of them, but not both. Have to clarify this, but that's what I'll follow.
Peace,
nightdiver
Waste the orings and use Viton seals in both intake and exhaust
If you cant find them try the isuzu C 240 seals with the same maesures
Try searching the board for viton and youll find the p/n that i donr have handy right now
Trust me cause this is my bussines and i sell these things daily
B
Blake
Guest
What's the part number and where can I get them? Tried a search on the internet. Can't find anything and don't want to buy a whole gasket set just to get the viton seals.
Thanks,
Blake
B
Blake
Guest
If any of you guys come up with a part number and where to get them, it would be really appreciated.
Blake
