Experienced leakdown gauge users, step in please.
4C FED
Absolutum Dominium
I bought one today from Harbor Freight for ~$28.00.
The instructions are not very instructional, but I think I've figured it out.
1. Set your regulator on your compressor first. Mine says no more than 100 psi. I have it set to 60 psi.
2. Rotate regulator on leakdown gauge fully CCW so you don't damage the leakdown gauge.
3. Connect leakdown gauge to compressor.
4. Adjust regulator CW on leakdown gauge until needle on % gauge is in the SET range.
5. Thread hose adapter into spark plug hole.
6. Rotate motor until cylinder you're checking is at TDC.
7. Connect leakdown gauge to hose adapter.
8. % gauge will now measure the difference from a complete seal (before I connected the hose adapter) VS when it is now connected to the cylinder via the hose adapter.
Correct?
Foot Performance
Re: Experienced leakdown gauge users, step in please.
I have seen some that have a percentage and other that just have numbers the one that work off % useually need to go up to 100psi all it tell you is how much air you put in (guage closest to shop air hook up) and how muck air is getting out of cylender (other guage) if you put is 60 psi and the other guage read 60 you have 0 leak down the reason the % type tester will throw you for a loop is you put 60 psi in and they will only read 60psi on the other guage and you think you have 40% leak down.
It is just easy for me to put them all at 100 and you will see how much you have
4C FED
Absolutum Dominium
Yes. The % guage is reading the difference between atmospheric (before connection to cyl) and pressure attainable in the cyl (after connection to cyl).
My only comment is that it is almost impossible to get the piston on exact TDC. Especially if it's not #1 or #4 (V6) which have the mark on the damper. When you connect the hose, the piston will blow down to BDC. No biggie, just don't leave your breaker bar on the crank bolt, and keep clear, because the crank will turn.
So with the gauge disconnected from the motor I'm only able to set the input regulator to ~14psi to get the % gauge into the set range. That seems awfully low when the regulator gauge has a 100psi range.
4C FED
Absolutum Dominium
OK, now I see that the instructions on the POS leakdown gauge I bought from Harbor Freight are wrong.
I found this on another forum.
I'm going to take this one back and get another one.
"I've got the same tester from Harbor Freight. The instuctions are wrong. I think the problem everyone is having is they are trying to set the tester while it is connected to the cylinder adapter hose (as the instuction INCORRECTLY state). The tester needs to be disconnected from the cylinder adapter hose to set the pressure. There is a valve that blocks the outlet while it is disconnected. This allows you to set the "cylinder leakage" gauge to zero. THEN you connect it to the cylinder adapter hose and take the reading."
I also found this. http://forums.pelicanparts.com/showthread.php?t=420340
I guess I could just replace the gauges with some better gauges.
4C FED
Absolutum Dominium
If I hook up the hose adpater to the leak gauge I get airflow. But there is no way that it is what my compressor regulator is set for, 60 psi.
It's only about the 14-15 psi that is displayed on leakdown gauge.
I don't see any usefullness in putting only 15 psi in the cylinder.
4C FED
Absolutum Dominium
But it won't stay at 15, once connected. After the hose is connected, the pressure will rise to the point of "leakage" lets say your set point is 100PSI. If it rises to 90PSI in the cyl, the guage will read 90%. (Or is it 10% ? Depends on which way the guage is scaled).
Put your blow-gun on it. Regulate different 'leakages' with the trigger, if you want to experiment. Or hook it up to the lawn-mower.
Yes, it stays at ~15 psi.
If I hookup everything except to a cylinder, I only feel 15 psi coming out of the adpater hose, not 100 psi.
ghettosled
SYTY SUPERSTORE
get a regulator and set the compressor to 100psi. get the cylinder to TDC compression stroke, and connect the hose. turn the leakdown regulator up till it reads 100psi and your % number on the second gauge is the amount of leakdown. The smaller the number the better. If you have more then 50% leakdown or you can not build any pressure in the gauge, you either have a hole in a piston, missing rings or hopefully you just dont have the cylinder on TDC.
I usually start with a compression tester since its quick and easy. If one cylinder is off from the others, I assume there's a problem and i bust out the leakdown to figure out where it is leaking (head gasket, intake gasket, valves, rings, etc)
4C FED
Absolutum Dominium
I did that & it wrapped the % leakdown gauge which basically fubar'ed it. After that it read ~40psi without ANY air pressure. So I disassembled the gauge & tweaked the borden tube a smidge to get it back to ZERO with no air.
I tried this with just #1 @ TDC. I went on to test all other cylinders without turning the crank. All showed ZERO leakage. It was interesting though, I could see the rings were passing air and then after a few seconds they would seal even with the 15psi.
I think this Harbor Freight leakdown gauge is a borderline POS.
It's obvious to me now that the % leakage gauge is only a 15psi gauge while the reference gauge is a 100psi gauge.
I'm going to buy 2 liquid filled 100psi gauges & install them in place of the junk that's already on & be done with it.
