External boost control Q's
MotorMouth
I am going to be using a Turbonetics Delta Gate external wastegate and I have done some searches regarding boost control with the stock boost control selinoid. I have found some conflicting information on if it is feasable or not. So, can I use the stock control with the Delta Gate? If so how do you do it with the dual port configuration of the external. The kit comes with a couple of springs (I can't rember the ratings off hand) so I figured that if I have the same base boost as the stock accuator it should work. If it wont work that is OK I can just use an manual boost controller but I figured that I woul try to clarify if this would work or not. Any help is as always appreciated. Thanks!
Brian
jwaller
Evil Genius/SyTy Guru
you can try it, and it might just work. but every truck is different and it prob won't work that well. but it will work. run a t off the wg sol to both of your ports on the dual wg. it you had the ability to write your own chips it could be made to work really really well.
smeagol
I'll host these for now, but it is my local server, so I'd appreciate someone taking these and hosting 'em longterm.
Top one is for a dual port external. The second one is setup with an external, but this is how the stock syty integral wastegate is setup.
:edit: linked 'em to Ian's location
MotorMouth
:eek: Wow!, that is what I was looking for on vacum line routing, thanks. Regarding the info on WG control, "If using WG P+I Control, the proportional values will need to be negative". I apologize for my lack of computer knowlage but, dose this info apply as the stock boost control values or are thier changes that need to be made to the computer to incorporate the above info. Thanks..
Brian
