external mounted walboro
sharkbait
i did some searching and couldn't really find a def answer.
im gonna go with a bradied AN feed and return line on the truck. An aluminum tank inbetween the rear frame rails.
my question is, can i externaly mount my walboro pump? i bought one a while ago. never installed it (my sy motor is gonna go in this spring.....hopefully)
ive read about running external aeromotives, barry grants, paxtons etc. but im wondering if i can use what i have?
oh, the build will be
stock turbo
bigger valves 2.02/1.60
422 cam
studded heads (was done before build)
AFPR
ultimate chip
WB02
built 700r4 2800 converter
373 posi RWD
im going to play with this set up using code59 after i get the motor running with the ultamate chip.then i want to max it out out with tunning. i want to learn before i start throwing go fast parts on it.
