External wastegate with ECM control
bender
I searched and searched but found little to answer my questions. I found that it is possible to control an external waste gate with the ecm, but not how or which waste gate, solenoid or actuator. can someone point me in the right direction.
Thanks
bezerk
Re: External wastegate with ECM control
with an internal wastegate you can. there are also boxes you can use, so you have a treu boost controller.
mscb or something. if you're intrested i have a brand new one
Stock ecm can control an external, just like it does the internal. You MUST be ready to make changes in the chip though, the ecm is programmed to control an internal which is marginal, a properly setup external is going to need some tune changes.
bender
I am putting together my stuff now to go code 59, so once I learn how to do it I should be good to go.
The reason I was thinking of an external is that my boost looks like a roller coaster. I see these flat boost profiles in DM files all the time and mine looks nothing like that. I would really like to get a smooth profile. Is it possible with the stock internal when tuning with code 59, or would porting the waste gate be the only way to do it with the stock WG.
Yes it is possible with CORRECT tuning to dial in an internal WG. At most you would need to do some mild porting but it is done and done many time.
The whole problem is the program is designed for a stock turbo, with cat, with restrictive muffler, stock boost level, well you get the idea. As everybody wants to go faster we throw a bigger turbo on, rip out the cat, change the muffler, 3" pipes, etc and everybody wonders why the stock ecm boost control doesn't work. DUH look at everything that was changed.
Your flowing more air in/out the WG naturally is going to need to flow a different amount also.
Its not rocket science, just takes some understanding on how a WG works and why so you know what to change in the chip.
