Will the rear sway bar off an Blazer Extreme fit on the back of a Sy? I know it mounts in front of the axle instead of behind. Other than that will it fit?
I've put this bar on a Syclone using the stock GM hardware. You do have to drill three holes to use the GM bracket and I would recommend doing it with the stock hardware. The main thing I don't like about using the other types of end links is that you have a very small grade 8 bolt trying to hold everything in place.
I have seen on other sway bars that the bolt will bend due to the force put on it by the sway bar. The GM end links I've used are much beefier and will handle the stress put on it.
I did manage to find the pictures. Looks like it was my old crappy digital camera that took them. I've got them zipped at http://www.warrrenbowley.com/syclone/swaybar.zip. I've re-linked the images in the other post, but without thumbnails. Hope this helps you Bill and anyone else looking to do this. If I ever drive the truck again I'll let you know how it handles.
