f.a.s.t useres got A question
1madgumby
Ok I have 75lb. injectors, MSD 6A,. Truck starts for 20 sec. & bam just shuts off, have been tunning on it for 6 hours today trying to figger it out. checked all wires hoses, O also Have A Arziona speed throttle body, put A new IAC no change, put stock throttle body back on, no change. The MSD makes the speedO jump all over, I can keep it running by peddling it, but will not stay idle. Im not 100% sure it is the fast causing the problum. IM open to any sugustions.
Aj.
jwaller
Evil Genius/SyTy Guru
Re: f.a.s.t useres got A question
you should be able to see a trend on the AFR's on your fast dashboard. what are they doing when it starts to stumble? I'd remove the MSD till you figure it out. I've had so many of them go bad I usually keep a spare. I'd bet you are probably needing to add fuel in your base ve table as 20 sec is about the time your afterstart tables wear off and you get to your base ve table.
my suggestion on the very limited info is to add fuel in your base ve table.
1madgumby
thats what I will try tommrow, your the second person that said this.
Aj.
1madgumby
ran it with the stock ing. & the stock TB. still no change. Not sure what to do from here. Anyone want to trade? have like $8,000 in the motor alone.
NecroWolf
lost marbles member
is your crank reference angle right? where does it idle while it does?
4C FED
Absolutum Dominium
Fuel pressure stays constant?
Do you have "Closed Loop" enabled?
If you do try unchecking it & see if it will idle.
You have email.
1madgumby
Fuel Psi. stays the same, crank angle is correct. will try it agin with the o2 in open loop.
Aj.
1madgumby
ok, put 2 different programs in the ecu, no change, tried old o2 no change, tried open loop, & closed loop no change. still runs like crap. if it will stay runing that is.
Aj.
Windedv6
Ty n 10s
Do you have the Original FAST or the FXI? Have you set your IAC and TPS calculations?
John
1madgumby
yes, been working with fast for the past hour. he is going to call me back here in A few. Will let you all know the out come..
Aj.
