f.a.s.t wiring harness
syco 2
i was just wondering im in the process of buying a fast system and was wondering if the is a plug and play harness.or is there anything i would have to splice. should i piggy back the stock computer and the fast???
jwaller
Evil Genius/SyTy Guru
Re: f.a.s.t wiring harness
once you convert to the fast computer there is no need for the stocker.
fast does sell(through retainers) a plug and play syty harness. all you have to do is run your O2 and injector harness from the fast box.
Maxtor
Others may sell the adapter harness as well, but I know PT&E has them:
(219) 996-7832
jwaller
turbotime also has them, They come from pte but anybody who has delt with pte would gladly deal with somebody other than them.
Maxtor
Agreed. Glad Eric at Turbotime is carrying them.
Tommyquest
The Member's Member
John, I can across this thread in a search and will be going to FAST soon. I'm debating whether to use the plug and play interface or the regular stand alone harness. I'd like to remove as much underhood wiring as possible and don't mind running the stand alone harness. I know there are basically 3 connectors that plug into the firewall by the brake booster. The largest loom that goes over the booster is the ECU correct? Can that entire part be unplugged and removed or is some part of that for routing power(alt.)? I've removed the AC, ABS, cruise, and air to water so I'd like to get rid of all the wiring associated with them.
BigAl...
you should consider the new XFI from fast. it has alot of cool new options.
BigAl...
MadPSI
Get the stand alone kit. Although the plug-and-play kit seems simple and appealing, it looks messy under the hood IMO...
10secTy
Sy-Ty builder and Tuner
BigStuff3 also has a plug and play harness for the syclone/Typhoon as well.
nolan
Tommyquest
The Member's Member
That's what I'm leaning towards. I have no problem at all taking the time to wire the regular stand alone harness. My question is can you remove the entire loom of wires for the ECM that goes over the brake booster?
MadPSI
If you know your way with the truck wire-wise then it's the best option. A lot of folks don't want to fuss with the rat's nest of wires in that area, but if you're at the point of using a stand-alone fuel management system, you're better off wiring everything else separately. It takes a bit more time to get everything else sorted out, but if you're trying to make everything look clean, it's the only way to go. You can easily reroute/eliminate all the wires going over the brake booster...
I've performed only one FAST installation with the plug-n-play kit, and in the long run I wish I did it the other way...
ViciousV6
400HP/550FTLB
I have Big Stuff3 on my truck. You Can Remove that whole harness only. It unscrews from the back of the fuse block and runs all the way over to the hole by the downpipe. There will be a few wires that i think you must cut but only 1 or 3 wires. The Big Stuff3 standalone kit is nice all the wires are wrapped nicely. This kit still has alot of wires but you can nestle them right by the dipstick or tranny and tie them off. My Motec wire harness was the bomb it fit right on the engine only but had no one to tune it.
I have Harry Anderson Tuning my Big Stuff3 right now!
Thanks Ralph
ViiciousV6
Tommyquest
The Member's Member
Thanks Ralph
ViiciousV6
Thank you Ralph. That was the answer I was looking for.
