F/S 40# HR injectors "accel"
Slyclone
Well-known member
I have 6 used accel 40# hr injectors.
These injectors have 3 "ports" on bottom three disc? Injection unlike stock pintle.
The number on these injectors are 01D114B 40/hr and 1991.? Not sure what 1991 is.
These might be good for a self tuner or some one who knows how to tune and properly dial in the fuel maps. I'm pretty sure my truck was not setup for them.
Asking $75 shipped.
Looked them up and they are around $200
Slyclone
Well-known member
Re: F/S 40# HR injectors "accel"
No flow sheet. They were in my GMC typhoon when I bought it. I thought they were 50# injectors and offered then to someone along time ago and I personally was mistaken upon further inspection.
The info I put up from racetronoix is most accurate as I read on a few LS1/6 forums they are advertised as a 40# but flow 37#.
They were in the typhoon and it ran like poo. I pulled more of the truck computer out and it revealed a chip that previous owner knew nothing about when I mentioned something. The injectors were not correct for the chip and I figured it all out real fast. Someone put them in at some point of a engine rebuild.( I ran the truck on the upgraded chip with stock injectors and it worked so I knew the injectors were the issue)
Check the racetronix information. There was a member who flowed a set of my injectors for me, I sent a set to him back in January-February and never got them back. ( no point reffering him )There's another member here also who's doing some type of additional $ervice with the same type equipment the other person I used has. Its up to you at that point to see what the flow measures are.
Slyclone
Well-known member
Bump, anyone interested in these? Cleaning up all my spare un-used stuff.
E85 and Methanol compatible.
Slyclone
Well-known member
Bump - anyone think these are usefull? Make reasonable offer.
