myclone
Been doing lotsa research into chip burning and have a few questions if I may....
I went here: http://www.chitownsyty.com/bg/chipping.htm and cut/pasted the following to ask about: "......Dig has been using some flash chips, the one to get is the Atmel 29c256. I buy my chips from JDR usually. The flash version of the Ultimate chip (the bigger, 32pin, 27c020/27c2001) does NOT work in our hardware setup."
Am I interpreting the above to say that there isnt a EEPROM avail that will take the place of the Ultimate only for the stock type 28 pin DIP? If not (no big deal IMO) then when using the AT29C256 is there a preferred access speed to use or avoid as they are avail from 70ns to 150ns?
F31M table.. I went to this link: http://www.chitownsyty.com/bg/chip_tables.htm to find this table (among others) and am lost on this one if the temp numbers are deg Kelvin as it states "Deg K" If you do the math and covert it to F or C then the numbers dont make sense to me. Is the "Deg K" just a multiplier or maybe supposed to be in deg C?... or do I need to go take math 101 over :-?
F28 table Hypothetical situation.... Would swapping the stock injectors to 72lb/hr would the following computations result in a ball park correct constant? 72/28=2.57 then.... .089/2.57=.035. Is .035 now the "new" constant or close to it for the 72lbers?
F30/F29 tables. After 4k rpm/OT (Open Throttle) how is boost accounted for to allow proper fueling? Is it based only on RPM (F30 table)? How is boost, 2 bar or 3 bar either one, figured into the fueling needs of the engine? Is this done via code rather than tables? ie: The code for the MAP sensor scaling is changed?
Could someone expand on or throw a link at me that might give some more detail on how the 3 bar is made to work where a 2 bar was used to begin with. Ive found info but its just not clicking for me (yet).
How about info on changing the code? The only thing Ive found so far is this: http://www.chitownsyty.com/bg/codechange.htm .
One last thing... Ive looked for info on what needs to be done to get the DIY wide band to work for us but havent found anything so far. Ive looked over the schematics on the DIY site but Im particularly interested in how its made to work so that it works with the ECM and what needs to be done so that I can log the AFR on datamaster.
Im doing LOTS of research (got 600+ pages printed/read so far) to try to get all the info I can before wasting ppls time and I hope none of the above has been covered a bazillion times but I somehow missed it. Im also not out to reveal any "secrets" or propriotory info to cost anyone $. Im just trying to learn. ANY info/links/sites anyone can provide is greatly appreciated.
As always TIA
As always TIA
