Factory air tube question
NJMatt50
I have a k&n filter on the truck. The hoses that went from the valve cover are just open to the air, is this ok or do I need to route them somewhere?
powercat6
Re: Factory air tube question
If I remember correctly the hose connected to the driver side valve cover connects into a fitting on the stock filter box.
If your K&N filter is a cone filter and you deleted the filter box; you'll want to remove the hose & fitting from the dirver side valve cover and place a small K&N filter in the driver side valve cover opening.
The 2 hoses on the passenger side valve cover should be connected to the 2 PCV valves which are mounted in a Tee fitting that connects to the passenger side valve cover. The rear PCV valve hose connects to a fitting on the throttle body and the front hose connects to the fitting on the crossover tube.
NJMatt50
Okay so the passenger side does have the 2 pcv valves but then is open where the air box should be. Is it ok to leave this open to the atmosphere?
TNPhoon
1of28
As said above the passenger side should go to throttle body in the rear and the air tube just left center of the truck.
Drivers side is only one that goes to airbox. Just put a vent cap there on the valve cover.
