Factory Boost Control Solenoid
HighPerformanceTrucks
Lift & Shift Specialist
I disconnected my boost control solenoid for my turbo uprgade and am going to reinstall it to work with the boost command.
Someone please refresh my memory. Does the metal nipple on the solenoid connect to the compressor housing and the plastic end next to the foam filter for the boost bleed connect to the wastegate?
I'm not using the stock hardlines with the new turbo setup.
Thanks for any assistance.
Adam Auerbach
Sy #2419
SeattleSy#1255
Category 5 Conservative
Re: Factory Boost Control Solenoid
Yes you have that correct!
kwick6
Adam Auerbach
Sy #2419
Yes thats it.
If you wanna get technical the line actually goes to the actuator, not wastegate. :D
Scott
Thanks you guys for confirming this for me.
No onto my next issue. :p
Please see my post in the tuning section about the connections from the boost command to the ECM. I'm having a problem locating the 32 pin connector labeled "F"
Adam
