factory crank shafts?
alaskan
was curious what the factory limitaions of the stock crankshafts for the different year blocks, and what the differences are, if any, from year to year. would really appreciate the help, or even a web site for the info.
autoaddictions
Re: factory crank shafts?
Stock crank 600hp. Cryoed stock crank 750 that about it. Must have splayed mains installed as well.
alaskan
600!!!???!!! wow wel i guess that pretty muchs helps me make up my mind on what crank shaft i'm gonna use... :tup:
turbodig
600, that is, if it doesn't ping. They won't hold 400 if they're subject to a lot of deto.
ViciousV6
400HP/550FTLB
On a similar note, how many hp will a nitrided stock crank be able to tolerate?
My nitrided crank from RPM lived for 2 years with about 10-15,000 miles of beating on the truck and 50 -60 track passes Truck ran consistant low 11 sec passes.
Ralph
VicousV6
Quickstop [UK]
Combating adversyty.
nitriding doesn't penetrate the metal, just the bearing surfaces. Cryo is a deeper structural technique.
wish i had cryo'd mine now
I wouldn't completely give up on the Nitriding. I will use an analogy that I think when thinking of nitriding. I don't if many of your guys are into boating, but a Boston Whaler uses two realtively thin layer of fiberglass sandwich by foam. On their own each is flimsy, but together they create a very strong structure.
