False Knock caused by ECM??
Question...Has anyone experienced a ECM causing 4-6KR at idle just by reving the engine?? My truck is doing this now. I disconnected the KS and just left the wire hanging, and it still showed 4-6KR when reving. So I know knew it was false KR and probably EMI. So the disconnect the KS wire right where it plugges into the ecm, and it still knocks when I rev the engine. So Ive eliminated it to the ecm. Would you guys suggest replacing ECM?? Thanks Fern
John,
When the sensor is disconnected, it still shows oKR, but just like when I rev the engine with the sensor connected, I get 4-6KR. I just dont know if this is normal or not.
What chip? Like john said it should show 4 deg constant kr with the knock sensor disconnected . With the stock chip mine would do the same thing that yours is doing.
sy538
I must have missed this when you posted it, or I didn’t know that my knock was false yet, I can’t remember when I figured it out. I haven’t tried it in neutral yet but it sounds like I have the same problem. I haven’t had datamaster very long and I haven’t paid for it yet so all of my runs are from a stop without launching (I try to only launch it when racing, and i haven't raced since I got it). When I go wot very quickly I get 3* KR immediately, before spoolup, it goes down through 1st to almost nothing then jumps a little at 1-2 shift (where I have 1-2* of real knock), this is very consistent. When I go wot slower, like take 2 seconds to push the pedal to the floor I only get the 1-2* of KR at 1-2 shift. I plan on getting motor mounts and/or tie down strap and expect that to fix the problem, but I don’t really know if it will. Have you figured out anything with yours yet?
Nop, but exactly what you explaining is my situation. A quick WOT blast shows 3KR immediatly, but goes right down to o. If I go to WOT alittle slower, I wont get that 3KR spike at the begining. I still think its related to the problem I descrided in my first post???
smeagol
Burst knock retard is enabled in the stock chip.
happens at heavy acceleration and such, like you are seeing, pretty much has nothing to do with knock sensor, as I understand it.
stock chip has 2.99 deg entered, well rather i should say SOME have 2.99, others have 0
4052 aybm
0x0100 KBKRTD1 ESC Burst Knock Retard Control 2.99 Deg.
1576 bbza
0x0100 KBKRTD1 ESC Burst Knock Retard Control 0.00 Deg.
Brian, how the F*%k are you so smart :eek: So basically if the prom was replace with the alternative mentioned than that should be eliminated?? So i guess this 3kr is not real detenation, just some safety measure bu7ilt into this prom?? Thanks Fern
