As some of you may know, I've been chasing a persistent false knock problem in my Typhoon since the last Nats. It has been driving me crazy. :x :x :x :evil: :evil:
I really appreciate the advice and input I've gotten, but I still need help.
I just replaced the valve springs. I was sure that was the problem, because two of the old springs had broken dampers. Unfortunately, that didn't fix it.
So, a description of the problem:
The truck has an excessive amount of valve train noise, but only when then engine's warm. When it's cold, I hear a nice, smooth sewing machine noise from the valve train. After the engine's warmed up, I hear a clacking noise that sounds just like a loose rocker arm.
I pulled the passenger-side valve cover, and tried re-adjusting the valves with the truck running. Unfortunately, I couldn't get rid of the noise. I even tried over-tightening the rockers (like a turn-and-a-half extra), but it made no difference.
I have a mechanic's stethoscope, which I used to try to track down the noise. I hear the noise loudest from the polylock on the #4 intake valve. A really loud clanging noise.
I have replaced virtually everything that can be replaced without pulling the heads or the intake. The list includes:
Does this sound like it might be a bad lifter, or does it sound like I need to pull the heads and get them rebuilt?
The motor only has about 12,000 miles on it. I wouldn't have expected any serious problems for a long time.
Thanks for your help, and for wading through this long post.
- Rocker Arms
Valve Springs
Valve Seals (did this with the valve springs)
Distributor
Water Pump
Throttle Body
