False Knock????
sy112
Well I just filled the tank with 5 gallons of Zylene and the rest with 92 octane and then went for a little jaunt. Could anyone give me my aproximate octane rating?
My knock did drop a little but it wasn't 0* like I had hoped. It now stays under 1* with some spikes to 3.5* according to TurboLink. I know this is good enough to run hard on but I there anyway to absolutely know whether knock is real or false?
My mix should have been stout enough to eliminate any knock right. Especially considering I was only encountering 3-5* with the "occasional" spike to 7*, usually on the TCC lock up. Not like I was having knock all over the place. My knock would occur on shifts then slowly work back down to 0* then jump up for next shift. Then always had a spike when TCC locked up.
Another thing I found out today is that my boost reading on TurboLink is about 3#'s over what my autometer says. Cause I played with the grainger valve today to try to squeeze the most boost I could on this good gas, and scared the shit out of myself when TurboLink was telling me I was having 18.xx lbs of boost :eek: .
Then went to the interstate and kept it fairly close to 10 lbs and TurboLink was saying between 13.5-13.7. I was wondering why I wasn't getting an overboost code, cause what TurboLink sees is what my ECM sees and that should have been enough to throw a code right? I mean it went to 18.xx lbs and stayed there! Is getting a higher number on a datalogger pretty normal, seems like I have read about this elsewhere.
Also, how can you tell if your transfer case is going out? Cause I am leaving some pretty severe black marks on my launches. Nice and fat!!!!! But I don't feel any slipping, truck gets a little "weird" feeling when I let off the brakes but I think it is because of the front wheels pulling not because the rears are getting loose. I am kind of skiddish cause last time at the track I was building boost and my rears atarted to spin while the fronts didn't. I never even felt them spin really. Only knew by watching the recording of the run. I was told that was a for sure sign the transfer case is on it's way out.
Sorry so long but today is my day off and I'm free to play with the truck. TIA
Maxtor
That sounds pretty close to a 2:1 mix - with 92 octane gas and 119 octane Xylene that woud equal around 101 octane. I don't know any way to determine real from false knock in your situation - but from the way it fell when you added the Xylene I think it sounds "real". Knock events will often show up at their highest levels at shift points because the engine is loaded the most at these points and fueling lags demand slightly. I guess you could put in a tank of C16 and see if you go to zero - but that's a fairly expensive test.
My boost readings are off around 2 PSI from my gauge too. The computer reads high. I think this is common. You have a good gauge, I would rely on it. The computer generated number uses inputs from the sensors (not sure here, but definitely MAP sensor, probably MAT also), and grabs a value based on these inputs. It doesn't correct for tolerances associated with this process.
