Fan belt is slipping
Goshinki
New engine isn't holding the fan belt properly
The belt will start riding up on the AC compressor and the thing below that. It moves out away from the driver by about a half of a notch on the belt.
It starts screaming after about 20 minutes of driving.
Tried the old belt and I have the same problem.
What needs to be adjusted?
Thanks for the help
bezerk
Re: Fan belt is slipping
prolly your powersteering pulley, since that is the only thing that comes off that could be installed wrong or bent.
Did this just start happening? Have done some other work recently to the engine?
This is a weird one. The "thing" below the AC is an idler pulley. Check to make sure that the bearing in the pulley hasn't gone bad. Also check that the attachment bold hasn't come loose. I'm thinking you have a serious miss-alignment somewhere on that side. Remove the top radiator shroud and inspect the big alum support carefully for a crack.
his engine was replaced.
OK. It still sounds like an alignment issue. You can sorta look down from above and get a general idea if the pulleys are aligned with each other. Might also jury rig some sort of a straight edge. Maybe it's the crank pulley and the belt coming off the idler is just a symptom with the cause being that the crank pulley is not on all the way? Without being able to actually look at it it's kinda difficult.
Just thinkin' out loud again.
SY2932
Administrator
Yep if your truck as a plastic pulley and it looks "faceted" due to flat spots on it, the bearings are shot.
bezerk
i agree 100% altough mounting back everythin is pretty straight forward but the ps pulley can be a pita.
