fan on the blink....
DanenGraham
Big in the rear
well my a/c, vent, heater all worked but only on the high seting. nice cold air or hot it would blow it out just fine but today when i disconected my batt to reset the computer they stoped working compleatly. looked at the a/c fuse but it is fine i can hear the ac turn on and the compressor gets cold but my fan just doesnt blow any more. could it be the swich or the fan... I belive it might be the switch because when it was working only on the high setting.. would like some opinions Thanks
Ian Turgeon
Cascading Inspiration
sounds like your gonna have fun wrestleing the hvac controls out of the dash. did it today.. tip: there are 2 pressed on retaining washers on the vacuum connections. got em off with a screwdriver, never to return. Stupid ass thing
jwaller
Evil Genius/SyTy Guru
could be the solinoid mounted on the AC housing under the hood. I have replaced 4 of them.
B
Blake
Guest
Pull the thing off that John is talking about and clean the contacts really good. If that doesn't fix it, replace it, it is called a resistor. I think those are 7mm screws. The reason your fan works on high only, it was bypassing the two other small coils in there. It is possible it may have corroded. It is really inexpensive. If that doesn't fix it, make sure the ground over the top of the fan is still intact(small black wire running down the blower motor) and make sure the purple wire is still plugged in good.
There is another device called a blower motor relay. It is the little silver box that a bundle of wires go into the bottom of. If the other stuff is ok, take a screwdriver handle and tap on the relay. See if it comes on.
In the future, pull the ECM B fuse to reset the computer. That way you don't lose all your preset radio stations and worry about arcing, sparks and other stuff.
If you have a multimeter, checking this stuff is soooooo much easier. They are $10 for a cheap one. PM if you have one.
Blake
Loeryder
If it ONLY works on high then its the Blower motor control relay.
Located on the heaterbox under the hood.
The metal relay near the pass. side, near the AC accumulator.
Its a cheap part and is not SyTy specific so AutoZone or Napa should have it reasonably.
