Q8.PREDATOR
hey guys ineed a oem fan shroud upper and lower with screws if anyone has it
also i need the air pipe that goes across the shroud
thanks guys
thanks guys
Will you only settle on an OEM fan shroud? If not reproduction shrouds can be purchased. I have used them and they are pretty good.
does is fit the sy coz the sy has a notch for the air intake pipe.. if it does .. where can i get itWill you only settle on an OEM fan shroud? If not reproduction shrouds can be purchased. I have used them and they are pretty good.
i cant find any over here.. so thats why am searching for the oem since am gonna buy oneThere is no difference between the SyTy and the LB4 upper shroud. (There is a difference for the L35 upper shroud, but it can be modified for the SyTy.) The lower half for SyTy is the same for all 4 wheel drive, 4.3 1st gen. The 2WD lower won't work at all on a 4WD.
I didn't know the lower shroud was different on the 2WD vs 4WD.There is no difference between the SyTy and the LB4 upper shroud. (There is a difference for the L35 upper shroud, but it can be modified for the SyTy.) The lower half for SyTy is the same for all 4 wheel drive, 4.3 1st gen. The 2WD lower won't work at all on a 4WD.
It may not be. I amended my post above.I didn't know the lower shroud was different on the 2WD vs 4WD.
It very well could be different on 2WD and 4WD trucks Dave. The only S10 type trucks that I ever worked on were 4WD/AWD, so I didn't know about the 2WD shroud. As good as your memory is, I would bet money they are different.It may not be. I amended my post above.
