FAST - AE Vs. TPS
GEN3Typhoon
Should the values in this table at any point go negative? I am having a hard time understanding why above a certain point you would want fuel removed with this table.
Right now mine is like this:
100% from TPS 0% - 29%
A straight line down to 51% at TPS 50%
Can someone explain this a little better to me?
TIA
G
Guest
Guest
hey Nick;
I'm no expert but...... "when the throttle is almost closed and you open it, the motor needs more additional fuel than when the throttle is already open quite a bit (cruising) and you open it some more, the motor needs less additional fuel". This tables allows the lower AE when already moving along.
Mine is set up as follows (NOT saying this is correct)
100% @ 0, 6.7% @ 21, -70.2% @ 50
Wanna discuss Cranking/Starting fueling and what's minimal fueling for a rapid cold start, yet keep it on the leaner side......... :roll: I'm trying to fiqure this one out now myself..... (groan)
I hope this helps....
GEN3Typhoon
Sure.. My truck has no issues with starting.. I have it set up pretty good.
What size injectors are you using?
I looked at a few different programs.. I am not sure that this should matter.. but I have three programs... mine 83#, a 72# and a program from a 32# pound truck.. mine seems fine.. the other are different than mine.
I will check this out when I get home and see if this table adjustment works for me.
I can send you my program if you want to look at it.
I will answer whatever questions I can.. I am not an expert either, YET!!!
G
Guest
Guest
Yeah, if you wouldn't mind sending me the program you are using. My cold start works (immediate startup) but you can tell by the black stain on the garage floor that it's phat. With a new motor going in, I'd still like a fast cold start still, but leaner. I'm looking to see where others are at to get an idea as to where the "thresholds" are at......
I'm even thinking of setting closed loop at around 70*, and using idle speed to compensate rather than fueling (for cold engine running). Lots of ideas, just not enuff experience yet.
e-mail addy under my post works for me...... thanks,
