In your case the distributor is just your crank sensor. So you wire the distributor directly to the FAST, and then FAST fires the 6A through the points output. This is a white wire on my XFI, I don't remember on the classic. The tach signal then comes from the 6A to the dash since you're not using the factory coil.
That make sense?
The MSD distributor is going to be an Inductive trigger. Look for "Inductive Crank Signal" or maybe just Crank. Is nothing labelled?
Sent from my iPhone using Tapatalk
IAC is probably working ok if it starts and idles.
There should be a wire for AC in the harness that tells the ECU to increase idle speed for the compressor kicking on. There's also a setting somewhere in the dash, might just be AC Enable I don't really recall. Anything labeled AC or anything about it in the Fast Track Harness instructions?
I don't see anything pertaining to a/c, could I connect the stock ecu back to the iac and run both? I see the dot on the fast ecu screen but it doesn't follow the line I'm telling to to.
