4C FED said:...
So, I need to disconnect the tan wire, crank the motor & set the timing to 6 degrees BTDC?
Thanks
Christian Dionne said:Even easier way.... just turn on the dashboard with advance degrees being shown. Set the timing light to whatever FAST thinks it's running, probably around 30 degrees at idle. You should have your 0 mark on your balancer line up with your 0 mark on your pointer when the timing light says what FAST is requiring. That's the easiest way with no disconnecting of the tan wire. You can set your crank reference angle to whatever number you want this way. I normally set it to 10.
