FAST Tuning - Question for the GURUS
GEN3Typhoon
Well I need to know if I am going about something right.
I have the truck basically to the point where it idles fine, starts fine, etc. hot and cold.
When I am tuning the part throttle, I have adjusted the tables so that there is no temperature compensation in them so that I will not be adjusting around variables. Is this correct?
I know I have to basically do my best to keep the truck in steady state with coolant temperature etc, to basically do this right, but am I moving in the right direction.
I have a stumble right off idle that i am trying to get rid of and I have reviewed the things I have seen in the forum and I will try that stuff tonight.
Thanks for the information
smeagol
Nick I had a long post all typed out for this post the other day, and hit submit, and it was lost when the submission timed out or something :evil: :evil:
Anyways, I'll try to remember what I typed.
Regarding the air temp compensation. Old versions of FAST (when it was Felpro/Speedpro) would ONLY use the air temp compensation table when it was in alpha n mode; when it was in speed density mode, the temp compensation was hard coded (you couldn't change it). This is good and bad. Good because this is how it *should* be, if this was a perfect world, and the computers could account for everything correctly. Bad because it's not a perfect world, and we should have access to the table, so we can calibrate & adjust for temperature, as the real world may not follow an equation on paper.
With that said, I'm assuming you have a newer firmware version that DOES utilize the table; this would be easy to test. At idle, crank on the table where the air temp currently resides and see if the AFR moves. I'm guessing it will.
Here's how I'd tune for air temp compensation. Setup the table how it should be setup theoretically. Theoretically meaning, calculate how much extra fuel you *should* need versus change in temperature.
Read this article to get an idea of what i am saying. Where to start? I'd start at whatever temperatures you have tuned most at. Probably 80-100° F air temperature. Leave those as is, and scale the rest of the table to fit the 'theoretical', using your 80-100°F values as an anchor. You should have a linear table, with more fuel in colder air temperature. You may opt to *not* lean it out at warmer than 100° F, as this might be a safety factor you want to apply. Meaning, as the air gets *overly* warm, you start getting richer again, to fight off detonation. This is typically how I've laid out this table on the trucks I've tuned that have the firmware utilizing this table. If you do follow this train of thought, you may want to look over your cold engine running conditions, as you have just now richened the mixture a bit. May help, may hurt.
Hope that helps in some form.
smeagol
Oh regarding the off idle stumble - let me know what you have tried, what worked, and what you are seeing. I have had to do a lot of tricks to get good drivability... once you play around, you can make it feel *real* good.
GEN3Typhoon
I made a few changes to the maps, just have not put them in the truck yet.. I am going to do that tonight.. I will let you know what I did and what effect it had.
I will post here in case anyone else is following the information.
I am reading that other article right now.
Thanks and I will be back tonight or in the morning.
EDIT: I read the article... PV=NRT.. reminds me of the good old days I spent as a mechanical engineering student.
GEN3Typhoon
Updated with files.
Updated with files.
Well Brian I got everything together and I found the disk where I made the changes to the file.
I have not done any tuning.. basically loaded the file and then ran up the street... just got up to about 5-7 psi twice. Looks like the IC is working pretty well.. not that I held it for too long.
Anyway... if you have a chance to look at these fine.. if not I understand, I plan on making some changes tomorrow when I get home. I should have a couple of hours to work on it.
http://www.usionline.net/020203file2.gct
http://www.usionline.net/042303log2.log
If you get a chance and you have some comments.. let me know.
I know there were some other guys who have been tuning.. so all comments are welcome.
You will have to save as and then change the extension,I am sure you know that.
GEN3Typhoon
Sure that would be great.. send it to nick.steffens@usionline.net
I drove around last night for about an hour and got some extra data.. seems the changes I made were a great improvement for the stumble, but my idle suffered some.
I will keep working.. and learning.
