FAST tuning question
Try Me
Well actually, i have tons of them if i could find anyone who knows about tuning the FAST system. I have the bank to bank setup.
One thing ive had problems with is a stutter almost imediately when you hit the throttle to accellerate and it shortly afterward goes away. According to the wbo2 its leaning completely out for a split second. ive tried changing almost every setting in the truck to make this go away with no luck. Its not affected when you stand on it because by the time the converter gets tight the stutter is gone. when you go to launch it it will stutter for a second then go away and spool up. I dont have much trouble now with the 4l80e and the 3500 stall getting up to 10-12 lbs w/ my T76 and its a blast when you let off the brake thats for sure. Anyway, this is more of a drivability issue that is more annoying than anything. I finally changed the "injector openning time" under the operational perameters from default 1.0 ms to 1.5ms and that seems to have completely cured the problem.
Anyway, ive had the truck almost 3 years and havent really had much of any help with tuning this system. Ive pretty much taught myself the workings and pretty much have it down i think, so im just curious about any others out there. Looking for any and all tuning suggestions, tricks i may not have found yet...
TIA
Windedv6
Ty n 10s
Re: FAST tuning question
What timing are you using at idle and off idle? What rpm at idle? Afr at idle and off idle? Fuel pressure setting? Are you running open-loop or closed-loop at idle? How is your IAC set? TPS enrichment setting? This table acts similar to an accerlater pump on a carb. Sometime the "L" key can give you a quick fix ...or at least a hint of which direction to go. I run a .9 pulse width. I am surprised that you don't have other tuning issues at 1.5 pw. What cam are you using?
John
Try Me
Ill answer what i can.
timing is 40degrees
rpm is around 850
afr is between 14.1 and 15.1 at idle
fp is ~ 38-40
closed loop
i think i need to clean the iac, but i dont know the setting
tps enrich for position or rate of change?
I honestly know nothing about the "L" key, please advise :)
the funny thing is that not much else seems to change, i think it may have fattened up the mix across teh board because it got a lot richer at idle when i did that so i dropped the fuel back there...
Windedv6
Ty n 10s
Here are some of my specs...I do have a custom cam that is similar to the 422 comp. And my intake is a single plane style which may have better distrubtion.
Try Me]Ill answer what i can.
timing is 40degrees
34*
rpm is around 850
930 rpm
13.8 netural - 14.8 in gear
fp is ~ 38-40
42 lbs with 84lb injecters. Usually run 42lbs with 50s, 75s, and 84s
closed loop
open loop till 1,200 rpm then closed loop. Back to open loop at 900 rpm(may help with the off idle)
To reset the IAC:
With the engine warmed up and the truck shut off,jumper the 2 top right ports on the ALDL.Turn the key to on (you should hear the IAC spinning.)Wait 30 seconds,then turn the key off.Remove the jumper.Pull the ECMB fuse out then put it back in.Start the truck.It should find it's own idle.
play with rate of change.
anywhere the curser is on the VE table...press the "L" key. It will auto correct to "0" correction. Of course if you go and change another cell close to it then you will need to come back and do it again, etc. But, eventually you can get the cells to starting working together.
you changed your whole tune with this move...you can over heat your injectors by running the pw's to long.
John
Try Me
Cool, thanks for the advice. I will go back out and make some changes later tonight. I do know that this started shortly after changing when it goes to open-closed loop. i changed the closed loop to be on at idle, wondering know if that didnt start the whole problem...
Maxtor
My numbers are very close to John's (see below). His motor and mine have many similarities and our tunes are reasonably close. I am in the same boat as you, self taught and trying to learn more as I go along. John has bailed me out more than once with his advice and has taught me several things along the way.
Timing - 34 deg
RPM - 1000
AFR - 13.5 neutral, 14.5 in gear
FP - 43 lbs w/84 lb injectors
Open loop until 1100rpm, then closed loop. Back to open loop at 900
Injector PW - 1.0
BigAl...
something that really helped my truck was idling at 13-13.8 afr. What is the timing just off idle? How bout you send me your file so I can see whats going on, netdet@bellsouth.net
BigAl...
Try Me
Thanks again guys for the suggestions, now if it would just quit raining...
Its typical that i dont think it rained a drop the entire month of september, in fact i dont remember hardly any rain since i pulled the truck apart in July to do the 4L80E, but i think it has rained everyday since i got the truck back running :(
