Fast xfi 2.0
gringo76
Got a fast xfi 2.0 laying around that came off a 4 valve mustang . Would it be worth putting this on verses stock old efi ? And does any body know how to wire in for cam sensing and crank signal from distributor ?
gringo76
Re: Fast xfi 2.0
dam sweet! pretty straight forward? I will call them today. once you get harness was there any other surprises to make it work or did every thing you need come with it. I keep reading something about having to use a buick knock sensor or 80 model camero's? thanks for your help. I looked on there site but only saw bucik harness
gringo76
Re: Fast xfi 2.0
when you installed the xfi did it help with drivability being sequiential injection and all? over all better? thanks again for you input
RealFastV6
@jb_and_his_coffee
Fast xfi 2.0
The standalone XFI harness you'd use is the TPI v8 harness. I don't know of anybody that is using the Caspers adapter.
Most are not running sequential either - but batch fire.
To run seq; We don't have a crank sensor so you'd need to add a crank sensor, figure out a cam sync, and then figure out your ignition strategy because you wouldn't be using the stock distributor anymore. That's a lot just to run sequential.
The drivability issues most people have don't have anything to do with sequential or batch fire- but rather basic tuning and maintenance. There's no magic bullet in the XFI.
The good news is like many standalone ECUs you get a very intuitive interface with wideband integrated that can be tuned easily on the fly - and lots of additional integration options. Yes you can add knock capability by using the ESC module from a GN - no biggie just a couple more wires to add.
gringo76
Re: Fast xfi 2.0
thanks for info. thought I would have to have crank and cam signal for it to be sequential but didn't know if casper electronics figured out a way to do it. mine runs fine but figured since I got a xfi system laying around the up grade to sequential or bank to bank gotta be better than factory. wish some one has used the casper adpt and get there input too on what has to be done for it to work.
Anarchy99
Re: Fast xfi 2.0
I'm not done setting mine up yet so I can't give drivability input. The caspers adapter harness I got was the last one they had, they stopped making them a few years ago. Ill report back when I get it all converted over, in the middle of moving cross country at the moment so it's all on the back burner. What do you modify on the tpi v8 harness to make it work?
