Ty 1885
Hey, well i found out that the harness from Caspers electronics is fine. The problem HAS to be with XFI itself!
When i crank it, the injector LEDs on the unit are flashing , but the injectors dont pulse.
There is power to the injectors as i crank ,but no signal from XFI. Everything else work , rpm, sensors, injector duty cycle, ext..
Has anyone had problems with there XFIs ? FAST are telling me that if the injector LEDs flash, that means the injectors are pulses.
ANY IDEAS???
ANY IDEAS???
