here is some info
Its very funny that I stumble on this thread after I have been to the junkyard to score a couple of fan assemblies from the lh platform Chrysler/Dodge(98-up).
I got one set for a friend and another for my 86 gn...
But anyhow I did some testing on them
The very interesting thing about these fans is the way they are wired.
The motors are wired in a way that there is 2 windings using a common stator/shaft. So when you apply 12v on one of the 12v wires (green or yellow) you get low speed from both motors. When you power both 12v wires (green and yellow) you get high speed.
I took the time to measure the amount of current draw the units use during start up and steady state running.
The low speed start up current is 42 amps.........The steady state current is 16 amps
The high speed start-up current is 53 amps .........The steady state current is 18.5-19 amps.
The battery voltage is 12.7 volts.
So the current usage with go up as the voltage goes up...But the motor output with also go up meaning more air flow!!!!!!!
Hope this is some useful info
I don't have any way to measure the actual CFM. But let me do some digging on how i can possibly measure cfm.
here is some info
I would have expected that the fan has two seperate windings, and you would not try to connect them both to +12v together. The 'slow speed' winding will be overspeeding if energised at the same time, (essentially turning into a generator) - not good! Might not be the case here, but the older Volvo's for example, use a double relay controller that switches the low speed winding out when the high speed kicks in and vica versa.
:tup:Damian,
Voltage = Current x Resistance (V=IR). If resistance remains the same and voltage increases, current must also increase.
Think of a dimmer switch in a light bulb. You turn up the voltage to make more current flow to make the bulb brighter. (Yes, I know the resistance goes up slightly but FAIAP, it's constant R).
HTH.
here is some info
I would have expected that the fan has two seperate windings, and you would not try to connect them both to +12v together. The 'slow speed' winding will be overspeeding if energized at the same time, (essentially turning into a generator) - not good! Might not be the case here, but the older Volvo's for example, use a double relay controller that switches the low speed winding out when the high speed kicks in and vica versa.
This is not the case here. Chrysler had the operation set in a way to reduce the amps of turn on load and also a way to control the engine temps in a closer manner.
the low speed comes on at x temp and then if the engine temp is not kept under control after x amount of time running low speed it turns on high speed. The reason for this is to maintain a closer target range of engine temp and for gas mileage. The less load on the alt. the less load on the engine.
I Also know for certain that high speed can only bee achieved by powering both 12v wires the current draw goes up and so does the RPM of the motors and more output of air.
also you would see a large increase in current draw with little to no change in airflow,motor speed. .
This is not the case here. Chrysler had the operation in set in a way to reduce the amp of turn on load and also a way to control the engine temps in a closer manner.
Ie low speed comes on x temp and then if the engine temp is not keep under control after x amount of time running low speed it turns on high speed. The reason for this is to maitain a closer target range of engine temp and for gas mileage. The less load on the alt the less load on the engine.
Also if thins was also the case you would see a large increase in current draw with little to no change in airflow,motor speed. .
Thats good then, I like that, sounds simpler than the Volvo set up too. I picked up a fan from a 90's Volvo (940 I think) shifts an awful lot of air, but the shroud is all wrong for our trucks.
A little off track, but still on the theme, but does anyone know which Volvo fan is supposed to fit our trucks or a fan/s off another 'US import' (i.e. European or other) that fits or trucks/radiator well. Removing the stock fan shroud seems to be a hurdle due to it holding the radiator. I had wondered if a 2nd gen S-series shroud could be modified to mount the rad as the tanks appear to share the same dimensions. Anyone care to post pics of their set-ups and how they are mounted and controlled? Whilst searching for inspiration, I came across this fan controller from Dakota digital that I've not seen mentioned on here before. Not cheap but nifty never the less.
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=852/prd852.htm
