fiberglass leaf springs
chad114
Is anyone running some of these in their trucks? I was wondering about weight savings, and performance enhancement. Are they good for a harder launch?TIA
jjorgensen52
NHSTE - I'm the only one!
Re: fiberglass leaf springs
weight savings I can tell you is about 100 lbs... haven't driven it like that yet though... lack of a motor, y'know :roll:
NOJIMMY
....depends:
1.Fiberglass springs must be mounted correctly (meaning use/non-use of wedges,
correct torque of bolts/clamps and use of extreme care as not to crack/stress them)
2.Heat will damage fiberglass (if exhaust is nearby)
3.Fiberglass springs come in many "ratings", like 215lb, 225lbs, etc
and ultimately stiffness and "rebounding" will be affected by load rating
4.Use of 'sticky' tires may/may-not change the dynamics of fiberglass springs
5.Use of "weak" shocks may/may-not change the dynamics as well
6.Use of ladder bars, traction bars, caltracs, etc may/may-not change dynamics
7.A change of gear ratios, tire pressures, and wheel adapters may/may-not change dynamics
Breakages can occur with fiberglass springs (due to the above).
canadian
sy in progress
Also be aware that the installation of a rear swaybar may cause contact between the end links and the springs. I have seen this on a Ty where the end link eventually cracked the spring itself due to contact.
NOJIMMY
...wouldnt surprise me if lowering blocks had an adverse affect as well.
mmp142965
say it like you spell it!
You are correct. However, usually you can get fiberglass leafs made to drop the vehicle a specified amount. This elimates the need for blocks.
Its a shame they interfere with the sway bar links. There is no way around this?
canadian
sy in progress
all depends on what type of sway bar you use. i went with the xtreme style that would eliminate any problems. i like it's design better than anything aftermarket out there right now.
mmp142965
Forgive my ignorance, but do you mean xtreme like the truck? or is that a sway bar manufacturer? If you mean the truck, this bar is a direct bolt on? You prefer it to the ATR rear bar? I was interested in both fiberglass leafs and the rear sway bar. How do you like your set up?
HighPerformanceTrucks
Lift & Shift Specialist
I've had excellent luck with the fiberglass mono leafs. I've never cracked one and my truck is very competitive in autox with them. I've launched many times including a 1.68 60' time with them. They weigh next to nothing and helps to reduce unsprung weight, not just overall weight.
I am selling my set if you are interested as my truck is currently having a custom road racing 3 link rear suspension being installed. I should have done this a long time ago, but PEP screwed me out of my rear kit.
Sorry to get off the subject.
canadian
sy in progress
I've had the first generation ADDCO installed, I've seen most of the others and the main thing I don't like is the dinky little endlinks. IMHO they aren't strong enough to hold up to the weight that gets put on them during hard cornering. I have seen them bend.
On my Syclone, I installed the S10 xtreme style swaybar with much beefier endlinks. While it's a bolt on, you have to drill a few holes to get it to fit. It would have been much easier to install if I took off the bed.
I'm sure it would be the same on a Typhoon (although no bed removal). You can see some of the install pictures at http://www.warrenbowley.com/gallery/main.php?g2_view=core.ShowItem&g2_itemId=927
There's always the discussion of sprung vs. unsprung weight, but I won't go with something I feel is inferior just because it's unsprung, etc. I'm not saying that every swaybar will hit leaf springs as I've only seen it happen in a Typhoon once. YMMV.
100in6
100in6
i had them on the stokes and never had any problems whatsoever. they are indeed lighter. i think installaton is an importnt factor in them holding up. also use good shocks. my sy would launch so hard that it would almost drag the rear bumper. think it hurt my times because it took too much weight off the front. need good shocks to keep from squattin the back end too much. i think almost a thousand pounds of torque had something to do with it. mark has not had any trouble with them since he's had it either. i think phillip had a set and one broke immediately. he went back to stock ones i think he went back to stock. they seem to make a softer ride in the rear so make sure you get good shocks and adjustables would be preferable.
mmp142965
Nice pictures, I am sure that will help out a lot. I guess you would have to pick your shocks, leafs, and sway bar all at the same time to make sure the combo works correctly. Sounds complicated.
NOJIMMY
__________________
Adam Auerbach
...Hey Adam, perhaps in another thread (as not to hijack this one)
you could talk more about the 3-llink. Ive been reading a bunch
about the new mustang (its a 3-link), and comparing the hodkiss/std
rear suspension (with/without upgrades such as shocks, springs,
caltracs, or coilover springs-overload leaf removal) against 4-link,
2-link, IRS, and bolt-ons such as panhard bars. Lots of complicated
things to digest, and havent seen any recent postings on material.
Not only would height adjustment, traction/handling, and weight
transfer be advantageous, but body roll, over/understeer and
tracking (with front end, set as various camber, caster, toe-in settings).
It just seems that the short track-auto cross guys are doing 3-llink now
(but I dont know of anyone with a syty conversion). I would think it
would be cheaper than some 4-link designs as well.
Like most things on our trucks, its hard to determine where-when to
stop-start, meaning does one change out front end components for better
stuff (balljoints, bushings, swaybar, shocks, etc) OR go to tubular
control arms/coilsovers (eliminating torsion bars, flipping keys, etc) OR
modify rear end (with shocks, springs swaybar, caltracs, etc), OR
do both front/rear suspension, or do a Marty/SoGT cut-transplant-rebuild.
Then there`s the "change out the carrier, axles,etc " scenerio while modifying,
all breaking the national debt (meanwhile complicating the best-bang-for-buck
theory).
thanks
Larry
I also have tham and plan to run caltracs with them. Ive heard on a sy they can casue the back end to be bouncy, the set of leafs i got are from WindedV6's Ty, i bought them along with the caltracs he had when he ha the comp fab rear suspension built.
Im hoping the stiffer Ty leasf will give me good ride quality and launch hard out of the hole and a i also plan to autox the truck in solo2 type racing.
But im still in pieces as well, so i havent been able to drive on them yet.
I think youll like them, more people have liked them and not had any problems then there are people that have had problems, it all comes back to proper installationm, you cant just torque down the u-bolts with an impact gun like you can with the steel leafs. and if you run caltrcs, put a piece of rubber hose around the bolt that hits against the top of the spring so it wont damage the fiberglass.
chad114
So what would a good rear suspension be without breaking the bank? What brand fiberglass leafs should I use with what brand shock (anyone ever ran the edelbrock ones)? Its too bad that a swaybar can't go with this combo .
leadfoot
Do not they get brittle in super cold weather making them prone to cracking? Any Northeast end users ??
Well, my plan incudes the Flex-a-form leafs in a Ty spring rate, i think that is a 245# but im not 100%, and i have the caltracs, along with an Xtreme S-10 rear sway bar and QA1 12 way adjustbale shocks made specific for the rear of a 2wd S-10, and i think they will fit a 4wd also.
I hear the edelbrock is a good shock, just not adjustable.
jjorgensen52
I've got monomax's on my Ty, but when I need new ones I'm going to get QA1 12 way adjustables... it's not a direct application, but they make shocks with the right fittings and length... or according to their product pfd they make 12 way adjustables for s10 pickup 2wd, not sure exactly of the difference, but it would match the adjustables on my RPM arms
