Finally got Datamaster, please help analyze
hatrik8
Please help me analyze my datmaster files. I got it up and running. The links are below with descriptions. I took 5 different samples. My problem is whenever I hammer the throttle in OD (sometimes D) while cruising I get a surge and fluctuation in RPM before it shifts to the next gear sometimes over redline. I think it's a transmission issue. Sometimes if I'm from a stop and use D and then shift to OD it will be better. You can see the oscillation in RPMs in some of the files. Any input would be helpful. I don't have the knowledge or experience to figure this out. I just know some of the stuff on datamaster. Too much knock? How does it look overall?
http://members.cox.net/hatrik99/syrun1.uni =20 min drive mostly highway fiddling around for the first time
http://members.cox.net/hatrik99/run2.uni =acceleration from a stop light, then slow down with another acceleration
http://members.cox.net/hatrik99/run3.uni = two accelerations from a stop
http://members.cox.net/hatrik99/run4.uni = acceleration from a stop
http://members.cox.net/hatrik99/run5.uni = acceleration from a stop then slow down then more acceleration
Info on My truck:
1991 SY
75k miles
180 thermostat
new brakes, new radiator
Stock except for:
-ATR Exhaust
-KN filter
-Walbro fuel pump
-Rebuilt tranny by local shop a couple months ago STILL UNDER WARRANTY :tup: (I know I know, local guys suck. I didn't really have much else of an option at the current time. He was recommended to me, said he knew about SY transmission and it's not the same as a normal 700r etc etc)
-Aftermarket stall or torque converter (can't remember which, what's the difference anyway? supposedly very good, can't remember name and details)
-IC pump hardwired
Thank you thank you thank you to anyone who can help.
Re: Finally got Datamaster, please help analyze
A couple of thoughts,
Your getting some knock Retard under wot 10 degrees, g
your tranny is shift too high of rpm if you have a stock chip yuor probably hit fuel cut (it also doesn't hp up their and it will short the engine life)
If you fix those two thing your truck will be noticably faster.
You say its a 180 thermostat but I am a seeing 195 temps. Your EGR is adding a lot of heat to the intake. Your WOT voltage is a little low 12.8V, it work better when above 13V.
hatrik8
Solution to this?
Ok, how do I fix this? Do I need AFPR? and what does "hp" mean? horsepower? That sentence is unclear to me.
I know it's a 180, but is it the right 180? Does a SY require a special 180 thermostat?Should I get a 160 thermostat? How can I keep my EGR from adding heat to the intake?
Anyone more opinions? Anyone else? Thanks
hatrik8 said:
Solution to this?
I meant to say it doesn't make Horsepower in the higher rpm range.
SeattleSy#1255
Category 5 Conservative
start with a full tune up using appropriate parts...then go from there.
