fired up the syclone tonight
E-Rue
first time the new motor has ran. i was kinda scared when i first fired it up. sounds like a dragster even with a full exhaust. wife is not impressed. ill upload a MPEG later. i noticed right off the bat that this was very different from what most people build. i got a startup file from nolan for the 75lb injectors, and it required quite a bit of tweeking, and i still havnt even got it to idle yet. any touch to the throttle or change in map causes it to go lean. gonna have to do a ton of work in the AE tables as well as the VE tables on this one. motor is extreemly touchy.... kinda like a race motor with a super light flywheel. did some homework and i think im gonna step up the AE/MAP table and the AE/TPS table by one click. im also curious about the timing. it dies when i let off the throttle. ive got about 29deg in it. anyone done any wild motors that can advise me on base timing? all in all a good day. i cant wait till im driving it around. this is gonna be wild.
e
Maxtor
I'm sure we have a lot of different variables at play, Eric, but I am running 34 deg of timing up to 1600 RPM.
HTH - good luck with the tuning.
canadian
sy in progress
I vaguely remember someone posting about their truck dying when they would come off the freeway and let off the throttle. It was either Green, Dig, or Barry T who had a solution to this. It might not help, but it might be a step in the right direction.
leroy
Vortecs can take more timing.
Work in open loop. Having an emulator really speeds things up. I'd start with the closed throttle VE table. Adjust it until you get the AFR you want....around 14.5:1 works for me. Then smooth out the table, and make a smooth transition into the open throttle table. That means the 800rpm/40kpa value in the closed throttle table should be similar to the value in the open throttle table. Now go to the open throttle table. In neutral, rev it to the rpms in the table, record data and adjust the chip to get the desired AFR. Smooth out the open throttle table. You should be able to drive it now.
Get some data at different rpm's in 1st gear, and adjust the tables. Repeat the process in 2nd gear. Smooth out the tables as you go. You should be getting something pretty driveable by then, and can start fine tuning AE, DE, and even consider returning to closed loop. I like to get some cruising data and shoot for about 15:1 there.
For WOT stuff, get a bunch of data at lower throttle positions and lower boost. Get that tuned right first. Start on the rich side, and work your way down. Once you get that right, you'll probably tweak the timing a little to get the best results.
Once you get all that done, you'll probably decide you could get the idle better and start the process all over again. :D
It helps to keep notes, in case some changes don't work and you need to go back a few steps. It also helps to only change one thing at a time, at least until you get some experience with it. If you are fighting mechanical or ignition issues as you go, it can really complicate things.
I'm sure there are other approaches to accomplish the same thing.
Jim
E-Rue
i got it mostly figured out...... it wanted a TON of timing. more than i expected. still fiddling with tip in, but its alive!
thanks for the tip, thats exactly what it wanted.
e
E-Rue
man this thing is wild.
stoopid sensative to the gas pedal.
cant seem to get enough AE around the 1000-2000rpm range.
it wants to "jump out" when you touch the gas..... never tuned anything like this before. lot of response. on version 18 of the tune, and i can drive it around and it idles. getting better and better with every burn.
e
Syclonewillie
When can I come down and go for a ride in this monster (truck, get your mind out of gutter) of your's E. If it is as fun as you say it may be the push I need to get the ball rolling again. Willie
Falco
nightdiver said:
i wish i would be there helping you. tuning my favorit part of the job :D
I might get you on this sometime... :wink:
E, I can't wait to see you monster going down the track... Keep up the good work!
Later,
Falco
nightdiver said:
Any time Falco . Do you remember the Astra with the 60-1 ? I installed a T67 in there :tup:
Wow! Do you have any pictures of it? But let's not rob E's thread away...
Later,
