First Datamaster run. Help!!!
Mike 2294
My question is that this graph does not show any “Spark Retard” during this run. It felt like it was taking out timing (I did not here any pinging) but not displaying it on the graph. What do guys think?
BoostedSUV
Re: My first Datamaster run.
How did you do 3:73 gears? You changed the ratio in both the front and rear differentials??
To answer your question, there isn't any KR showing on the graph or in the knock count/spark retard area either. My Graph will show a straight line across the bottom for the spark retard when there isn't any but I'm not seeing that on your graph either.
BoostedSUV
Just curious, how did you post screen shot of DM?
Goshinki
Press "Print Screen"
Paste it into Paint and crop out the DM section.
Then upload it to a photo center like imageshack.us
Then post the image here >.>
**Notice the sides of his picture have a background because his crop was quick and sloppy =P
BoostedSUV
**Notice the sides of his picture have a background because he crop was quick and sloppy =P
cool thanks! :tup:
BoostedSUV
i don't have a "print screen" option, I only have "print engine record" and it doesn't look like a screen shot and there's no option to copy or paste? what am I missing?
bundie
when you hit print screen on your keyboard.
go to paint and press ctr+v :tup:
BoostedSUV
I tried hitting print screen on my laptop and I can't get it to do anything with DM. If I open anything else it will work but not with DM :rant:
EDIT: i figured it out. Have to use the "snipping tool" with windows vista :tup:
laidback292003
life begins @ 20PSI
hit print screen then go to windows paint then ctrl v then print it like a pic, it is a trick that should work
