First Datamaster
X
xanth
Guest
Hi everyone,
Finally got datamaster set up on my truck. Hopefully the link for my first file is below :D
It's kinda a long drive (about 15 min or so), but had a nice warmed up idle, and a WOT run in there. Starting about 587 seconds.
Looks pretty decent to me... but i'm hoping an expert can take a look at and tell me what they think. The truck does not feel as strong as I think it should be....
Looks like it shifts 4475-4500, 100% TPS at WOT, boost is a little funny, makes 15 PSI, but at WOT it's not really steady....
I'm also showing zero knock during 99% of the drive.... is that normal? I know you want zero, but i figured it'd show some more. gets up to about 1.6 at 678 seconds....\\
Engine temp around 200 (have a stock thermostat) and IA temps seems to be pretty normal, making it up to 160, but seeming to stay 100-120 or so. I have the IC pump hotwired and it is working.
It shows my AC clutch is on....but my AC does not work, clutch is not working.
Also, the vaccum seems really low during WOT (like -4?)
http://rapidshare.com/files/414135869/first_drive.uni.html
Appreciate the help! :tup:
Mods:
rebuilt engine ~1500 miles ago, bored .030 w/SRP pistons, hotwired IC pump, Warblro 255 Fuel pump, new turbo (1500 miles on it), solid engine mounts and pretty much every sensor is new (except the knock sensor). New everything else when engine rebuilt (plugs, wires, distributer, fuel filter, all that type stuff)
WyoSyclone
Re: First Datamaster
You're right.... it seems a little slow. My Sy is basically stock (Stage1 turbo, 40lb injectors) and I'm trapping 95mph at the same point at the end of your run (your trap is 76). Your timing and boost is good, iat's OK. Hmmm.
The vacuum at WOT is normal. On a naturally-aspirated car if you saw vacuum at WOT it would indicate an intake (carb) restriction.... yours is simply showing boost. You've got 16.5inhg at idle which is a little low but OK.
The wobbly boost is normal for a stock truck - yours varying by a couple of lbs at shift points.
Tranny seems to be a little lazy shifting - the 1/2 shift isn't as crisp as I would think it should be.
This is a stock chip?
X
xanth
Guest
Yea, it's a stock chip.
Maybe it needs fluid/filter change. truck has a tad over 58K on it.
X
xanth
Guest
Anybody else have any thoughts on what/if anything is wrong?
