First technical question for code59 users...
Aaron Staub
Really looking for confirmation more than anything else so I'm sure I understand the mechanics correctly. I just brought home teamvortecs 92 Ty yesterday and I am all set up to check the tune. I did a little driving around, logged the data, dumped into autotune 1.7, and got recommended fueling changes. However, some of the VE output is now greater than 100, which as I recall means it is useless. The current bin has a BPC vs EGR definition of 158. I presume I need to bump that up by a scalar factor (call it 20%) and then I can take the autotune F29x output and bump it down by a similar 20%.
That sound right? Makes sense in my head.
Re: First technical question for code59 users...
Yes, you got the idea correct.
If it is only over 100% in boost sections, then you can use the F77x table instead, different way to do same thing.
Aaron Staub
So I took a little data last night and looking for some feedback. Obviously everything looks lean across the board. Couple thoughts from my perspective. I could bring the A/F down by addressing the VEs in the F29X table, but some of the boost cells (which I didn't get into in this run) are already near max and Autotune is telling me some of my duty cycles are high. Thus I presume the correct first step is to check fuel pressure and plan on raising it up to knock the A/F curve down across the board. I also note that the A/F is a little bit sluggish to move once boost begins to come in. That would mean I need to build a little more into the bottom part of F77X?
Also, I found it odd that on the first boost here I only got a very small amount of KR, but I got a LOT on the second event. But the shape of RPM, TPS, and boost are almost identical between those two profiles. So why would one give a bunch of KR but not another?
At some point get away from autotune and do it manually, autotune was designed as a comfort blanket for new tuners. At some point you will find it makes more sense to figure out the cells manually.
What do you have for injectors? The 2nd event maybe more pronounce because the engine is hotter from the 1st event.
Aaron Staub
I just got this rig on Saturday, but advertised as stock injectors, stock turbo, stock I/C. Base timing curve from the SBNova bin on code59 repository. Bosch pump/hotwire/AFPR in the fuel system. Haven't verified fuel pressure yet as I need an adapter for my gauge (on the agenda for this evening).
Is there an established upper maximum for fuel pressure with vacuum hose off? Flow varies with the square of pressure, so if I want to bump flow by 8-10% I will need to bump pressure by 16-20%
Bumping pressure is going to get you very little gains past say 42psi, especially on stock injectors. You can verify pressure increases with boost but beyond that don't try to tune via pressure to compensate for a fuel table(s) that isn't correct.
42psi base, stock injectors be fine for that combo I would not run a different fuel pressure than that.
It's just a six
Super Member
I ran as high as 55 psi when I was running stock injectors & 21 psi of boost of boost pressure.
I saw a noticable difference in A/F ratios running 42 psi then increasing it to 55 psi @ W.O.T..
42 psi was the absolute minimum base fuel pressure I would ever run when using stock injectors.:2cents:
I believe Dig would run as high as 60 PSI IIRC. Maybe it was 55psi? Dig?
Aaron Staub
Appreciate the input guys. I was thwarted in sourcing a -4AN adapter fitting locally, so I'll order one and just borrow one tomorrow from VatoZone to confirm where I am at.
Aaron Staub
Made a little progress last night. Fuel pressure currently set at 50 psi with vacuum line off, and 42 with vacuum line on. I didn't take the time to post the curve yet, but I added about 10% to the idle, boost, and cruise sections and pulled about 5% out of the decel sections. It's probably a little fat now, but the KR is better. While I am still getting some, it doesn't seem to slavishly follow the boost profile. Instead it would pop in for just a second and then quickly decay away. WYOSYCLONE has generously agreed to help do some side-by-side analysis, so I'll keep this thread up to date.
Aaron Staub
Does anyone have a bin file of an absolutely bone-stock factory tune? The code59 repositories have some starter tunes and Tooky has the Ultimate chip bins. But I am getting some KR with a really mild timing curve and pretty rich fuel map. If push comes to shove I would have no qualms about just tossing in the factory settings so I can drive it around a bit while I learn more about code59.
