fix a stripped caliper bolt?
Ian Turgeon
Cascading Inspiration
anyone have any ideas of what to do with stripped caliper bolt thread on the spindle? Ive seen what looks like replacements with oversized threads for just this purpose.
Anyone have any experience with this? Adam stripped one out on his truck and has been too lazy to fix it for about 2 years...
Figure I'd get him motivated.
AndrewB
I've gotten them from Napa. Have had no problem with them, I had to install one on a Grand AM. Actually the bolt worked very well. Hope they'll work for Adam as well.
SYO237
SyTy Registry
heh... lazyness rules.
anyhow.. shed some more light on the matter....
whichever guy owned the truck before me had the brakes done and whoever did them striped the caliper guide bolt.
so, when i got the truck and go to change pads which was long ago, i find this nice surprize waiting for me.
so basically, the spindle is the part that is stripped out.
Ian has told me about these oversized threads....
I was thinking of welding the hole back up and redrilling it and tapping it again. though, this would be some serious work and i cant fuck up on redrilling the hole crocked...obvious reasons.
new spindle... to expensive, and im not about to do suspension work again... F that.
the helicoil i thought of doing, but didnt think they would hold up under the braking power if you really had to stand on the brakes for a period of time, like in a emergency stop.
but hell, i see jeff used them.. andrew recommends the oversize thread, looks like i need to goto napa and spend some money.
what exactly am i looking for in brand name?
The bolt in question holds the caliper from falling off. The braking forces are not necc. transfered through it.
The Helicoil IMO is the best solution. In fact a helicoil is done properly will be stronger than stock thread, as cast iron is fairly weak.
Helicoil for that size wasnt' cheap. i do still have the kit in my toolbox. I could possibly be pursuaded to send you the kit, if you guarentee its safe return. I think I still have the proper drill bit even for it.
Again been 5yrs since I did it, 40k miles, 3 brakes jobs, not a hint of trouble.
SYO237
SyTy Registry
thanks for the offer jeff...
let me see what i have available on tools from a friend who owns a shop...
if not, i may hit ya up....
i may return it.... if you send it with some poly motor mounts with it... ::thumbsup::
hehe...
syclonekid43
i just did a heli-coil on a 94' blazer last night. i used part number 1208-207. made by perma-coil. it is a 7/16 - 20 inch fine thread. all you need besides this kit is a 29/64 size drill bit.it was easy to do and there will be no effect on braking.the kit retais for $35.64.
