(fixed- ICM) roadside assistance lol
sae
So I'm parked here on the side of the road, truck died and coasted to a stop and now it won't start. Cranks fine just will not start. I put a new ignition coil earlier tonight, I put the old one on and that doesn't work now either.
Any ideas? I have limited tools, 1/4" drive socket set, no meter
sae
Re: roadside assistance lol
Ecm b is looking good. Ign/gau is good, ecm 1 is good. Definitely have fuel pressure
sae
Checked all wire connections and they are good, from coil to distributor, the pink and white wires are connected good, not touching or burnt
Slyclone
Well-known member
Hard to say. When the ICM fails it will show the RPM gauge bounce when cranking. The ICM is located inside the back of distributor. The other end of the pink/white go to that.
What are your cranking conditions?
Sean Krupa
Moderator
Can you hear the Fuel pump prime? Maybe hit the tank then try to crank.
sae
I hear pump prime and can smell gas after trying to start it for a few seconds.. The tach doesn't move at all.. Still a good chance that its Icm?
Slyclone
Well-known member
I'm not that good at roadside diagnosis. My next thought would be a beat rotor, or a bad cap. Idk if you can pull a wire ground it out and see if you even have spark.
sae
Cleaned everything up inside cap, good amount of build up on contacts.. Hopefully I can start it otherwise ICM? I put this one in a year and a half ago, definitely need a new cap and rotor though.
Never posted that but no luck. Cleaned as much as I could on rotor and cap and didn't make a difference
sae
ICM it was. Had to wait until gf got off work at 11:30 for a ride to go find the original icm which was buried under mouse crap in the back of garage, just put it in about 20 minutes ago and it fired right up and made it home.
Thanks for the quick replies
Slyclone
Well-known member
Re: (fixed- ICM) roadside assistance lol
What kind of coil was it you put in?
Glad some basic trouble shooting worked.
SEL777
One of 101
Good job, welcome to the life and times of SyTy ownership.
