Apparently whoever "fixed" the fuel lines last opted to use oversized hose and 7 clamps with 3 parts of hose and no unions vs one piece of hose and two connectors. Needless to say it was leaking in 3 spots and the hose pulled right off the cut up metal fuel line.
Luckily it was an easy fix but it leaves me wondering what other pieced together crap I will find after the leaking IC core with putty, tek screwed cladding that started falling off all around, and now this.. probably should've checked the brake lines to make sure they weren't 2' sections with compression fittings from autozone. :roll:
