FIXED No full throttle with TV cable connected
Did a little searching so excuse if this has been asked and answered.
Anyway, like it says. I've good full throttle up against the stop -without- the TV cable attached but with it I've only got about 95%. IOW about 3/8 of an inch between the throttle lever and the stop. Thrans shifts normal both hwy and strip, but there is (and always has been actually) what seems to me to be a lot of tension in the TV cable when throttle nears full.
So, anyone else experience this? Had my cable out and it "looks" fine but no way to tell if it's stretched unless someone has an overall measurement they can give me. I've added a spacer between the pedal and the cable so there is -0- slack before cable moves with pedal.
Ideas appreciated.
Jimmy
Banned
Re: No full throttle with TV cable connected
I'd look at gas pedal travel.You can do it on Datamaster with the key on.
I had to bend the arm for my gas pedal down in the middle a bit to get 100% since it hit had hit floor so many times before I bought it.
nastety92
I'm pretty sure we had to bend mine back as well when I was having this issue.
Nick
ty166
It goes full throttle without the tv cable so how could it be a pedal problem ? I would think a pedal problem would limit it with or without the tv cable attached. Sounds like a cable problem to me or a mounting bracket problem.
I'm kinda with both ideas. I'm gonna look again and see if I missed anything. My guess is that there's just enough stretch when the load of the TV cable is added it dosen't quite make it the full throttle. The pedal, where it pivots, has that little stop. I need to check if that is an issue as well.
Thanks guys.
Removed throttle peddle, heated and bent the rod. Roughly brought the pedal 3/4" closer to the driver. Installed an alum spacer between the rod and the cable. I now have full throttle. Lever is up against the stop with the TV cable attached. Pedal is now slightly off the floor when FT is reached. I may now rig up a stop to prevent a damaged or broken cable.
