I've read a few complaints about the gaskets not staying in the plastic Vortec valve covers after they've been installed and removed a few times. Well, it happened to me when I was swapping the valve springs.
The problem: The rubber sealing ring gets pulled out of its groove, and won't stay in when you try to push it back. In fact, it seems like the seal has "grown" and is now too large for the cover. Usually happens on one of the corners.
The solution: Pull the seal completely out. Use some brake cleaner (or other solvent) and completely clean the oil out of the groove in the valve cover. Use the same cleaner to remove all the oil from the seal. Wipe everything down, wait until everything's completely dry. Then, reinstall the seal by placing it over the groove and pressing it back in. Start by pressing in the corners. Then, press in the middle of each side. Continue by pressing in between the last to places that were pressed in, splitting the distance between them -- this prevents stretching the rubber during the install. Work all four sides at the same time -- do all four corners, then all four middles, then the 1/4 spots, etc. Once the seal's back in, go around one more time and make sure it's completely pressed in.
The cause: The seal is only held in place by friction. So, if any oil gets between the seal and the cover, the seal will just pop right out. The cure is to clean the oil out.
