TurboJunk
questionable
As im driving the truck seems to loose power for a second then regain it. as this happens the check engine light blinks. it happens mostly when trying to going into boost (giving it WOT). now my thought are that maybe the computers loosing power or ground.
If im correct the computer gets power from the two wires that go to the 2 screws on the firewall by the AC box..... and 2 wires go to the fuse box. and grounds from the 2 wires that are usually boltsed to the back of the drivers side cylinder head. Since my batteries in the back i have a wire that goes from the battery wire on the starter to that junction block on the firewall, for power.
this started to really hapenn friday evening when i pulled over to reset the computer by pulling the ECMb fuse out. after that it has been going crazy.
what makes me think the computer is temporary loosing power/ground is there will be a code coming up , then it will happen and when i go to check the code theres nothing in code history.
Anyone have any thought on my dilema....
