Flat tow a Sy
DaveP
Re: Flat tow a Sy
What's wrong with AWD?
The biggest advantage with full-time AWD is with braking. It's very difficult to lock one wheel when all wheels are mechanically linked together. A secondary consideration is that the 5 RPM V-clutch slippage limit may be exceeded when towing, especially with all the hills on I-25. I doubt the mileage savings would be much. If its working, leave it alone.
I towed 10's of thousands of miles with my Blazer AWD. I really liked the confidence it gave me. Your 94 should have 3.73 final drive ratio which will help a lot. You'll be fine, with no engine in the Sy, this isn't going to be tough at all.
I'll post pics tomorrow after I pick it up of the set-up.
DaveP
Re: Flat tow a Sy
Just got back to the house with it. The hook up went smoothly. I took surface streets home, but it seems to track just fine. Tires look good. I'll check it over (diff oil) and other stuff later.
It's a nice rust free Syclone. The underside of the bed is VERY nice. It's missing some valuable cladding, and is kind of picked apart, but for the most part it its solid.
Here's some pics. I'll updater later.
mattw
Re: Flat tow a Sy
I'm surprised it towed well for you.. I towed this Ty years ago.. It also did not have an engine/tranny and at highway speeds it would want to shimmy side to side. I attributed it to the lack of weight up front and the suspension geometry being off with the front end so high in the air..??
I'm pretty sure we have the exact same Reese tow bar. I've used it to tow other S10s that did have an engine/tranny and they towed perfectly..
V8 Sonoma GT
Mile High SyTy
Re: Flat tow a Sy
thanks aaron
correct me if im wrong, a stock rear syty wheel is the only one you can use as a spare, it would just stick out really far in the front...?
DaveP
Re: Flat tow a Sy
I flat towed my #1230 home from Florida in 2000 with no engine, and it towed OK. I haven't had Ron's up to highway speed yet, but I can usually tell how it is going to track at speed by how well it responds to low-speed turns. I think it will be fine based on what I observed today during the 15 mile trip back to the house.
I'm not worried for my 500 mile portion of the trip, I'll be towing with an 8,000 lb Super Duty. No way will the tail wag that dog. Ron is towing with a 94 Bravada for almost 900 miles, so it needs to track well for him to be safe. If it isn't tracking well enough, we can dial in more Caster in Tucson. It's easy enough to do, and we'll have resources available at my buddy's garage in Tucson. It'll be safe, or it won't leave Tucson (or my house) until it is. That's the way I do things.
I originally bought my tow bar for tmy 91 S-10 4X4 DD. I have permanent brackets for the tow bar mounted above the tow eyes, and wiring provisions so the lighting is plug-n-go. I used to frequently move the yachts between harbors in So Cal. Getting back to my car was always a PITA, requiring another driver. I'd tow the DD to the destination for the boat with the Blazer, leave the truck, take the Blazer to get the boat, take the boat to the destination, then drive the truck back to the Blazer and go home. I could move a yacht by myself without the need for a 2nd driver. I added the cross bar for the SyTy work a few years ago, and it has worked well for those too.
I probably have 20,000 miles on my tow bar. I've never had trouble with tracking. My concern is often with braking. Until a year ago when the Super Duty entered the fleet and braking is no longer an issue, my tow car was another S-series. Some of my combined vehicle weights were in the 8,500+ lbs range. That's a LOT for 2 axles of stock s-10 brakes. I had to pay attention to not getting into a situation where I couldn't get stopped.
Tomorrow will be spent getting all this crap loaded for a 10 day trip. All my trips are multiple-mission. This one is delivering parts, doing an NCRS event in Denver with the Corvette, working on some C4's in Tucson, and a Quadravan in Breckenridge. Lots to get done.
The plan is coming together.
DaveP
Re: Flat tow a Sy
thanks aaron
True. But I think a rear rubs on the front cladding. A front will contact the frame before the wheel contacts the drum. So road wheels aren't great spares, unless you have one of each.
Your Syclone does not have a spare. The Bravada's spare will work for the Syclone. I will probably bring a spare for the Sy just in case I need one during the trip to Tucson. (The SD's spare will not fit. :grin:) You're welcome to take mine with you and return it with the rest of the stuff when we meet in Denver later in the week.
V8 Sonoma GT
Mile High SyTy
Re: Flat tow a Sy
yea the Bravada has bigger tires (nothing crazy), with a spare to match them. but i just remembered I have a Ty spare, duh...2 spares cant hurt, and the Sy spare wont work on the SD :)
Im prob over-doing it with the stuff im bringing, but oh well...
thanks a million dave, happy to finally meet you on Sat
DaveP
Re: Flat tow a Sy
Except for packing my clothes, and wrapping-up some office work, I'm ready. Leaving at 0400. There's pretty good cell coverage the entire trip, and the SD has bluetooth, so call anytime. Let me know how you're progressing. Travel safely.
Jay: I'm on-track to be in Tempe at 1100, so see you then. Your parts packed nicely, they should arrive blemish-free.
Here's some pics. The bed of the SD is full to the brim. So its good to have the extra cargo capacity of the Syclone bed. Much of the crap in there is mine. :grin:
berzerker
wookie
Re: Flat tow a Sy
Safe travels everybody . Ron good score on the sy . Hit me or Cheatam up if any parts needed .
fivetodrive
CRISPY
Re: Flat tow a Sy
Ron, That definately looks like a nice sy to start with! I should have transfered Crispy into a Sy like that!
V8 Sonoma GT
Mile High SyTy
Re: Flat tow a Sy
safely home. ill update soon. Thanks everybody for the support. Dave, you are the man. See you Thur.
DaveP
Re: Flat tow a Sy
Ron went 100 miles out of his way last Thursday, and came up to Loveland to return my tow-bar and other bits he used to get his Sy from Tucson to home. This entire escapade worked out flawlessly because the people involved knew what they were doing, did what they said they'd do, when they said they would do it. I wouldn't hesitate to get involved with another deal with Ron. Totally stand-up dude. Thanks, Ron.
I'm in Breckenridge, chillin' till Tuesday, then I'll head back to Los Angeles. Spent 3 days with NCRS Corvettes, including mine; will end up being a nice 12 day reprieve from the grind.
V8 Sonoma GT
Mile High SyTy
Re: Flat tow a Sy
i certainly dont know why you are thanking me when YOU did me the favor. I will get out to LA someday and we can hang out longer
V8 Sonoma GT
Mile High SyTy
Re: Flat tow a Sy
Ok everybody, let me say, it was not as "nice" as I thought, but still a good deal. the seller made sure not to mention both side rear bed cladding pieces were cracked. the rest of it knew about. i didnt know the L rocker pieces also required bracket, which i do not have, so oh well. I will find both L's and the one door, and it will be complete (if not some cracked). Interior missing console door, and shifter. But hey, it has a perfect X-over tube so...
anyways, onto the rest of the journey...we headed out earlier than dave by about 3 hours.
The bravada started throwing soft codes 600ish miles in, but kept resetting with truck on/off. When we eventually met with Dave, and his friend Tom, who had many NICE Vettes, we embarked on my first ever flat towing experience.
and the auto addictions/syclone is painted on..argg....
at one point the brav claims it was 120...
and 113 at night...
i was worried about towing at speed, but by the end of the trip, i was doing 75mph towing it.
made it home..my friend and i may have a problem with caffeine...
3 sportmachines...
syty
and then i met Dave to give his tow bar back, and the Corvetes were nice...
all said, flat towing went great, i plan on making my own tow bar set-up, and will gladly tow a syty with the bravada again..and it got 10mpg towing on the highway...
