flexplate/flywheel and bolts for them?
ed hess
race or get outta the way
Flexplate (is this the same as a flywheel, I think so but you never know)?
Flexplate: 168 tooth B&M #20239 Flywheel: Stock GM #10128414 Which is it.
I was going to use this one from b&M 20239
Flexplate bolts: I cant find the thread fromm this one?
Think i might find an answer at:
http://www.arp-bolts.com/pages/products/products.html
I hate the damn search function......
ed
By the time this is done ill probably hate the sob that WAS (past tense)going to do this moor for me to!
MikeRenz
not stock
careful with those ARP bolts. I ordered them, but the heads were too big and you couldn't get a socket onto them when trying to torque them down on the flexplate.
Also...with your mods you might as well get a SFI approved flexplate. Its a lil more expensive, but just in case you get into racing more, might as well have it now.
ed hess
mike the B&m unit is sfi approved.
I dont understand what you mean about the bolts not being able to get a socket onto them. Tell me more please?
ed
4C FED
Absolutum Dominium
Ditto.
Been there, done that.
ARP's do not fit.
The heads will not clear the flange of the crank.
ed hess
ok so what did you use.
I am not going to use the old as they are still in the old motor in the truck.
I need to know what to buy. Did you guys call arp and ask them.
I still dont understand why they dont fit.
Looking at the crank end the 1/8" think part that protrudes out 1/4 inch...
are you saying that after i put the flexplate up to this that the diameter of the bolts will hit this flange when they are tightened down?
which of these arp part numbers did you use that wouldnt work:
100-2801 200-2802
or
socket 330-2801
4C FED
Absolutum Dominium
I just bought new stockers.
The head of the bolt is to large in diameter.
This prevents getting a socket to sit square on the flexplate to torque it down.
Here is a quick depiction of the problem:
sy2185
Moroso bolts won't fit either. I used ARP 12 sided bolts and just shaved the wall diameter of a cheap socket bout 1/3 the way around it w/ a grinder. Worked great.
Jeremy
ed hess
b&m flexplate and bolts are due here monday so i will see. Hard to beleive that the B&M flexplate would be this thin at the mounting point.
Something is odd here, but i will see. The cheap socket grind down
sounds like a workable fix.
Possibly a bolt with an internal socket like torx or allen would solve this.
ed
