I am getting a flutter when I hit 10psi. Truck runs great, no codes, spools fine, can make boost as long as under 10 psi, it feels fine. Hit 10 psi, power goes away and I start hearing a flutter sound coming from the turbo area. You can feel it in the truck slightly.
Here is what I have done:
Took air filter off to make sure it was not coming from intake and re-secured.
Took turbo to IC hose off and re-secured.
Thought my IC to Throttle body was loose. took off and used T-bolts to secure.
Thought my boost control solenoid was bad so I went back to boost valve.
Thought waste-gate actuator was bad, took off put old working one back on.
Prior to this happening, had waste-gate ported, 3"DP put on. Truck ran fine when I got it back for about three weeks.
Any help would be appreciated.
Jay
