mattw
For some reason my flywheel seems to be rubbing the torque converter cover under load.. I have:
1) Checked tranny -> engine bolts.. They are all present, tight, and the motor and tranny are properly seated.
2) Checked motor mounts and tranny mount.. All good.
3) Checked the 3 bolts that hold the TC and flywheel together.. All present and tight.
4) Grabbed the flywheel and tried to move it.. It seems tight all though I can not see/get to the bolts that hold the flywheel to the crank so I can not confirm that they are all present and tight.
5) Started the engine with TC cover off and watched everything rotate.. It all looks straight and doesn't appear bent/warped.
My question is, what could be causing this? Could my TC have expanded some and be pushing the flywheel towards the engine? Any other thoughts?
Thanks,
-Matt[/img][/url]
