FMIC help
protechmn
ok so i got my intake gaskets 2day, thanx Hood, and installed my lower intake and decided i'd mount my new fmic that i bought yesterday from a gentleman in Amarillo. it has this pt# on it LOP3259AL it is new and came w some brackets to mount it to the existing bolts that mount under the frame. the way i see it i have to either eliminate the complete shroud that goes around it stock, or fabricate a completely different shroud. my question is, what are the pros and cons of eliminating the shroud? or should i fabricate one and intergrate a scoop? any suggestions would be greatly appreciated, thanx in advance.:tup:
Chest Rockwell
Re: FMIC help
I think what you bought was a Dequick lower heat exchanger. Search for that and you should find some pics and hopefully answers to your questions. BTW, did you pick up his whole pile of parts?
protechmn
Re: FMIC help
thanx, ill ck that out...and no i only bough the heat exchanger and the trans oil pan. i already have a set of vortecs and he wanted to sell everything as a package, but we might work something out and ill be selling the heads and some of the other stuff he has...
elorejas
Re: FMIC help
so your the one that bought the heat exchanger he had said it was a guy moving to kansas that was from the valley as well small world well i bought the vortec heads from him
